Need pinion angle advise
I've had a vibration problem for a while above 80mph.Have changed wheels,driveshaft's,gears ect with no help.So today I got under and checked the pinion angle and found it to be +1 degree.The torque arm is a non-adjustable LG motorsport.
So my question is can I just put some washers in the tranny mount to raise the front and SHOULD help me get a negetive pinion angle??
Thanks
Thanks
Re: Need pinion angle advise
When i changed my torque arm to the adjustable BMR unit we checked the pinion angle before the install and found i was at a -1 pinion angle with the BMR LCA bracket set in the bottom LCA setting,so i would say to install a set of BMR relocation brackets to get the negative side out of your torque arm since it's not adjustable.
