New torque arm out, link inside
I really like the added tunnel clearance on the side, I bet they are not that hard to make, if you could make a custom bracket for the rear end to move the upper and lower mounting points in more and up higher on top.
I wonder if you could actually just make tabs on the standard 9" rears and then make a torque arm like that???
yup, i have some custom engineering on mine, i think i have a pic that sort of shows it around here somewhere......
shows the lower side, top is the same, and there is a little brace on the pass side too, to triangulate it
there is at least an inch all the way down, even where the fuel line is...that i have to move lol. (nhra rules no fuel lines in driveshaft tunnel) all these rules...one day it will be legal for something...maybe.
Post a photo of how much you notched yours, I am using my stock tank and I can just cut it and make room on it too since I already cleaned out the gas and have it ready for welding on.
I already covered the factory fill tube hole and drilled and welded on the cap up top.
I'll notch that thing all the way up to the top, I just need to know how far to go width wise, besides losing a couple gallon capacity will help with weight, how much will yours hold?
Sorry but since we're on torque arms and clearance might as well throw in up top clearance too
i dont have the tank inside, and if i hit it, something has gone very very wrong!
but it only holds 7 gallons.....and lets see... I can go about uh lets see 1 mile on the track, and umm about the same on th return road.....like 2 miles on it
The moser peice was designed for maximum tunnel fit. This tq arm is a peice of art, not just another tq arm. For the money the M9 package is a steal, a full chromoly tq arm and x-member and 9" fab housing. The tq arm has a slider up top for the xmember and as well as an adjuster in the rear for angle. 1.28 60fts so far on radials, not too shabby for all of 6 runs on the car.
hmm, I got a weird one for you...i have 12 bolt gm gears in that rear, in a 9 inch style center section, I have no idea where it came from either so i cant answer that, and somebody does make a 9 1/2 setup that uses dana gears, for a fab 9 housing. But that moser piece is pretty beasty looking.
As far as the dana 60 gear, the only one I know of in a 9" uses a 9.5 gear, I didn't know if they were dana gears, because the dana is a 9 3/4" gear.
Strange also makes those, it's big bore case, not the 3.250 the next size up 3.812 and 4.0 bore ultra centers. It will run a 9.5 ring gear, but the thing is I want one with dana gears setup like a dana, it has a better pinion placement compared to the 9" so it will be more efficient.
So something like the 12 bolt in center for the 9" housing, except a fabbed housing with a center section with factory located dana 60 specs that will drop into a fabbed housing.
