et streets, got a question
i got some 26x10.5x16 et street drag's. is it ok to run them with wide front tires.?
my fronts are 275/40/17. i thought i read somewhere not to mix slicks with radial tires, but not sure.
i'll be using the et streets at the track only.
thanks
thanks
its not as bad as people make it out to be. although some cars are worse then others with the slick walk.as long as you dont go dropping the pressures down to 10psi or less it should be fine. i ran my et streets at 14 hooked awesome and it didnt walk that bad out the back.
