Front a-arm issue/k-member
The slots on the front k-member....lined it up, tightened everything good. I know it was all tight I did it myself.....
Test drove the car, and when I turned it around the drivers side slid all the way outward on the slot.
Whats the fix for this? I can't be the only one that has had this problem....Is there a washer with something that will grab? eccentric kit etc.? It just has flat washers on it now (what came with the complete kit)
Thanks for the help
Thanks for the help
I locked a wrench on one side and tightened it with a 3 ft snapon ratchet......I know it has at least 150 ft. lb. on it. I'm 6'4 285# I been powerlifting for about 10 years...I got plenty a pair to tighten this bolt. I'm dissapointed of the crappey design. I have also worked on cars (been an online tech) for 15 years......most all these type adjustments will have teeth on them or some type of eccentric washer or something
with aftermarket a-arms and k members sometimes you have to set the alignment properly and then tack weld the nut/bolt to the k member. just enough to keep it from loosening but not enough to make it a hassle if you need to grind the wled off to readjust or remove the parts.
I had this same problem.
I found out that the sleve inside the a-arm bushing was not long enough and was causing the bushing to deform while the sleve was not making enough contact with the a-arm.
Fixed by getting a longer sleve for the bushings.
Hope this helps.
Ted Z.
Hope this helps.
Ted Z.
