Switching from 325/50 to slicks, what size slicks?
I want something close to the same size, but want them to clear when they grow. My fender openings have not been altered. My 325's are close to the fender openings now.
I am minitubbed, rear narrowed 3 inches per side with a 5 in bs wheel.
29.5x10.5 slick?
28x13.5 ET street?
David
29.5x10.5 slick?
28x13.5 ET street?
David
I ran a 28x10.5 slick and then switched to a 325/50 MT radial. The slicks would grow a little at high speeds and rub the back of the fender opening. The radials don't grow hardly at all. A 325/50 radial is wider than a 28x10.5 slick (ET DRAG) and a little shorter. According to the Mickey Thompson website, the 325s are pretty close in size to a 28x11.5 slick.
fastfatboy, put a 30x10.5 hoosier radial slick on it. if you can get a 29.5x10.5 under it the 30x10.5 hoosier slick will fit. it's only 29.6 and it will not grow. better 60ft times and et with radial slicks to. i have been 7.7s at 170 on them
David,
I have a set of 28x10.5 stiffs on bogarts you are welcome to test fit if you want in Pensacola. They are 7.5 bs, 15x10's. They just barely touched in the front without a lil love over 120 mph, where the standard 28x10.5 didn't. I guess the S's are a hair taller.
John
John
