Drag Racing Tech
Another cage install question. Working on it now
Old 01-05-2008, 02:08 PM
waltsfastz's Avatar
Default Another cage install question. Working on it now
Im in the prosess of installing my Wolfe 10 pt cage. The best I can figure the Main hoop is about 1/4 inch too short on the driver side. Going by Body measurements the best I can, And with the passangers side top side bar level the drivers ispointing up hill, towards thefront of the car by 1/4 inch.
What do i do? Can I shim it or is that a no no. Should I just leave it, Shouldnt throw anything off exept it looks kinda shitty.
THanks fellas
Old 01-05-2008, 07:09 PM
Rogue86's Avatar
I wouldn't know why you couldn't weld another plate or however much is needed onto your floor plate on the short side to shim it up a little bit.
Old 01-05-2008, 07:58 PM
waltsfastz's Avatar
Thats waht I figured, I talked to a local guy that does cages and he didnt see why it would be a problem. I took a piece of 1/4 inch, Drilled 2 5/8 s holes in it and weled it and the holes to the plate. probebly the strongest part of the cage if you aske me
Old 01-05-2008, 08:09 PM
RAGENZ28's Avatar
Make some outriggers and tie them into the subframes, you can install the outriggers above the floor so it'll raise the location where you weld it in.
