How have you guys routed the hose to your airbag?
I need to know how to run the line to be clear of all harms. Also where is your fitting mounted? I thought it would be cool to put it in the fuel filler cap area. Quick responses appreciated.
Thanks,
Stan
Thanks,
Stan
Re: How have you guys routed the hose to your airbag?
I have mine mounted under the bumper on the right side. As for the lines be careful of the upper panhard rod.
Cheers,
Chris
Cheers,
Chris
Like it was said on the passenger side you can route around the PHR just, make sure you don't place to where is can pinched between the the upper and lower PHR. Also stay clear of the exhaust ...
On the frame beam there's two holes ... I just tie wrapped it to that and then tucked about 14 inches of hose into the hole. When I need to check I just pull it out ... works great they're out of site easy to access and no holes drilled in the bumper ...
I routed mine up through the rubber grommet in the spare tire well then had the air valve in the plastic panel of the car that covers the spare, just open the hatch, and add air!
I used 3/8" fuel line to shroud the line anywhere it may get a hole.
