Drag Racing Tech
What anti roll bar to use
Old 01-15-2008, 12:08 PM
1_bad_ss's Avatar
Default What anti roll bar to use
WHich one to use I'm thinking the BMR drag bar. I want a good one that I can also use with factory gas tank and I know there is one you have to use a cell with. What are your thoughts one what is my best bet
Old 01-15-2008, 12:26 PM
allmotor's Avatar
Talking
I have the BMR XSB001 on my car and it has worked fantastic. Car is 98 firebird with a stroked n/a small block and it will cut consistant 1.28-1.30 60ft times also have BMR lca's panhard rod k member and a arms.
Old 01-15-2008, 12:34 PM
1_bad_ss's Avatar
Thanks that's what I was looking at also
Old 01-15-2008, 05:17 PM
bad2000z's Avatar
I just ordered BMR rod-end lca's, phb, and a drag sway bar last week. I've heard great things about that bar.
Old 01-16-2008, 12:36 AM
LS1TECH Sponsor
CutlassRacer's Avatar
Also check out the new piece from TRZ. It is lighter than the stock stuff that you take off of the car Total weight for everything is 17 pounds! This includes the Panhard Rod, Panhard Rod Relocation Kit and the chassis style ARB, all Chromoly Tubing and TIG welded. The only welding you have to do are the tabs on the rear end. Clears a stock gas tank by a mile and also will clear a single 4" exhaust pipe.
https://ls1tech.com/forums/drag-racing-tech/825862-new-trz-arb.html#post8254136
Old 01-16-2008, 12:38 AM
CaMaRo67RS355's Avatar
i was looking at the bmr or spohn is the wolfe one the one you have to get a fuel cell for?
Old 01-16-2008, 06:49 AM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
yes and no on the wolfe. they sell one that you can use your factory tank.
Old 01-16-2008, 10:04 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,087 Likes on 716 Posts
I have the BMR drag bar in the Camaro, 1.38 short time left straight as an arrow.
Old 01-16-2008, 11:26 AM
1_bad_ss's Avatar
I guess it's looking like the BMR it is
Old 01-16-2008, 10:17 PM
TwnTrboCE's Avatar
Both cars have gone 1.26 60's using all BMR products.
Old 01-17-2008, 05:32 PM
bad2000z's Avatar
Old 01-17-2008, 07:11 PM
black01_WS6's Avatar
I will be getting the BMR drag bar. for steeer use and occasional track use it seems to be the best.
