Drag Racing Tech
Old 05-13-2016, 03:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
"Weight Reduction List" Fully Updated!
Old 01-21-2008, 01:28 PM
Dave 96TA's Avatar
Default try this
I only changed a few descriptions
50 Catback
45 Seat, front (leather)
42 Hood (LT1)
41 Carpet & Sound deadening
37 Spare tire and jack
35 Spoiler (Weight measured on a Pontiac)
35 Seat, driver's (cloth)
33 Seats, rear (leather)
30 Seat, passenger's (cloth)
23 Gas Tank (steel)
21 Bumper, rear reinforcement and brackets
21 AC fan motor
20 Headlights/metal frames
20 Bumper, front reinforcement and brackets
20 Gas Tank (plastic)
17 Panhard rod (TRZ kit)
15 AC compressor
15 Speakers
15 Cats
15 EGR, air pump, & harware
15 Side impact bars
14 Airbag and bracket, passenger's
14 Swaybar and brackets, front
12 ABS module
12 T-Tops
12 Power steering pump, pulley, idler pulley
11 Dash
10 Center console
9 Heater core (w/water)
9 Seatbelts (rears and passenger's)
8 Heat sheilding
8 AC condenser
8 Windshield washer fluid
7 Firewall Insulation
6 Wiper motor
6 Gas, Extra (per pound)
6 Speaker panels, hatch
5 Speaker panels, rear passenger's
5 Dash Pad
5 Gas Tank Evac Box
5 Panhard rod brace, upper
5 Coolant Overflow
5 Windshield wiper reservoir
5 Amp, Monsoon
5 Fenders (Inner)
5 Cruise control
5 Floormats
4 Overflow Tank
4 Airbag, driver's
4 Hatch cover
4 Wiper arms
4 Crossmember brace
4 Dash Replacement
4 Antenna, bracket, and motor if applicable
3 Inner fenderwells, plastic
3 Horn
3 Sheetmetal, extra double walled
3 Head unit
3 Foglights and brackets
3 Panels, under steering wheel
2 Glovebox
2 Hatch shocks
2 Bolt lengths, extra
2 Intake Silencer
2 T-Top holders
2 Headliner
2 Sun visors
1 Rear view mirror
1 Lug Nuts (Chrome)
1 Owner's manual
1 Misc junk in the car like keys, garage remote, change, etc
1 Door panel insulation (ea)
1 Washer fluid pump
1 Grill insert
1 Air filter
1 Hood shocks
1 MAF
Brake pedal pad
Shifter ****
Power seat motor
License plate brackets
Liscense plate(s)
Fan
Power window motors
Head unit/AC console trim piece
Blinker switch
Ashtray & lighter
Parking brake handle
Under car tow points
Wiring, Excess
Parking brake
Coating, under carpet
Spring isolators
Air dam
Power brake booster
Emblems
Taillight(s)
FRA mod
Fan shroud
Old 01-23-2008, 02:45 PM
z28evans's Avatar
So, what will a decently gutted (no A/C, etc) but street driven 4th gen weigh?
Old 01-23-2008, 04:35 PM
John_D.'s Avatar
Originally Posted by wrecked vette
can i pull the ac box out and still have the heater core, do the units separate?
You have to cut them apart and install a block-off plate over the hole in the firewall. There are a couple of threads going about this.
Here's one of them:
https://ls1tech.com/forums/lt1-lt4-modifications/711439-c-firewall-stuff-removal.html
Old 01-23-2008, 05:30 PM
SJM Manufacturing Inc's Avatar
Our Bogart wheel weights are not accurate. Depending how we build them affects the weights. A 3.5" front runner can be as low as 6.75lbs, rear as low as 9.5lbs. Weights are dependant on the sytle, series used and how they are put together. The typical F-body design has a front at ~9lbs, ~10lb if we are building them to OEM specifications.
you can shorten this post if you like...figured I'd add a bit of info for explaination.
Old 01-26-2008, 10:28 AM
TwoFast4Lv's Avatar
Here are the photo's of me doing the LS1 heater box I put in My 95 Z28
Old 01-28-2008, 11:55 PM
SSmokin 01's Avatar
Hmm 50 lbs just for the front brakes? Anybody actually weighed them?
Saved 35lbs on the fronts and 31.5lbs on the back. 12lbs for the parking brake.
Old 02-01-2008, 03:35 AM
Jantzer98SS's Avatar
I have a huge list of weights or weight reduction of atleast half of the weight reduction I have done, but I will need to find it. Here is a couple from the last couple days though.
9.8 Wipers/Motor
8 Hood Latch/Brackets
30 Sunoco Bolt-on
6.2 Dash Brace(steel piece)
12.6 Plastic/Insulation on Firewall
2.2 Visors
I will be weighing the kirkey drag seats tomorrow before/after the swiss cheese.
Old 02-03-2008, 10:27 PM
THEBRAD's Avatar
subscribing
Old 02-05-2008, 11:00 PM
Demonicbird00's Avatar
today i removed the side impact bars.....
i also removed the back bracket for it where the 15mm nut is (where the door lock mechanism is) that weighed 2.75lbs. so for both they weighed 5.5lbs if you wanted to add that as well
i lost 22lbs total today from both doors
-brandon
im debating of taking the wiper motors out as well....and just making sure i have my windshield waxed at all times in case of rain....but im not sure yet
Old 02-05-2008, 11:07 PM
Nimitz87's Avatar
whats a set of 3.5 x15 and 10x15 prostars weigh? no tires.
Chad
Old 02-05-2008, 11:15 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
10lbs each for the 15x3.5s
I read on here that 15x8s are 13lbs, so I would imagine that the 10s would be 1-2 lbs heavier
Old 02-05-2008, 11:25 PM
  #32
Nimitz87's Avatar
thanks
so we'll say the 15x10's are 15 pounds a piece = 30 pounds.
+ 20 for the fronts = 50 for wheels.
what are stock 17x9.5's? 40 a piece?
so thats 160 in wheels.
slicks weight 25 pounds? so 50 for 2 slicks
skinnies are light as **** 20 pounds for both?
so 120 pounds for skinnies and slicks compared to what stock?
200 +?
whats the savings going from 275/40/17's on 17x9.5 z06 rims all the way around to 3.5 skinnies and 10" slick?
Chad
Old 02-05-2008, 11:53 PM
  #33
Nimitz87's Avatar
Originally Posted by Nimitz87
thanks
200 +?
Chad
did the math myself...skinnies up front are 17 a piece 275 DR's are 26 a piece + the 70 in wheels = 155lb.
275's on all 4 corners = 104 lb.
17x9.5 OE concept Z06's are 26 pounds a piece. = 208 total
208-155 = 53 pounds rotational weight.
Chad
Old 02-15-2008, 12:28 AM
  #34
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I'll add in what I've done so far to my 93 Z28:
Front Bumper Support = 25.375 lbs
Fog lights and brackets = 4.0625 lbs
Cruise control, cable, and throttle cable cover = 4.4375 lbs
Air pump and brass fittings = 5.9375 lbs
Stock horns = 1.875 lbs
Stupid siren and loud horn = 2.5 lbs (Ignore)
Stock Y pipe and single cat = 21.1875 lbs
Old 02-18-2008, 09:00 AM
  #35
LS1TECH Sponsor
Jon@BruteSpeed's Avatar
Close to 50 on the LT cars because of the difference in spindles and the amount you have to cut to get the brakes to fit.
Strange front brakes= -40.9 lbs.
Cut LH spindle= -3.83 lbs.
Cut RH spindle= -3.69 lbs.
Total savings in front brakes= -48.42
Old rear brakes= 23.10 lbs. each
Wilwood race brakes= 11.37 lbs. each
Total savings in rear brakes= -23.46 lbs.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old 02-24-2008, 09:48 AM
  #36
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Door panels for the Trans Am are 9 lbs. a piece. I just pulled & weighed mine.
(I'm keeping the arm rests and covering the rest of the door in either aluminum or vacuforming plastic)
Old 02-24-2008, 12:56 PM
  #37
thats an interesting route....keep me posted on how it comes out
-brandon
Old 02-24-2008, 02:14 PM
  #38
Orangepeeler's Avatar
You're a poet...and didn't know it.
Old 02-24-2008, 06:46 PM
  #39
snk-huntr's Avatar
i got my side impact bars loose but how do i get them out of the door?
Old 02-24-2008, 09:10 PM
  #40
RAGENZ28's Avatar
cut them with a sawzaw!!
Quick Reply: "Weight Reduction List" Fully Updated!
