Cage install in Progress
Well,
The cage install is progressing!
On friday night, I finally pulled the dash out of the car and started tearing into the heater box and air bag.
On Saturday, I got the floor plates welded in place. And started fitting the front down bars.
Then yesterday I got the main hoop, the rear down bars, the front down bars the front halo bar in and the Drivers door bar all in place. I'll try and get some pictures up this evening.
I have a question for some of you technical types. It has to do with how this sentence is worded.
If you take out the () and Commas, it reads, Unless an OEM frame rail is located below and outside of the drivers legs a rocker or sill bar is mandatory in any car with a modified floor or rocker box within the roll cage uprights.
In my case my floor is unmodified and my rocker box is outside of my uprights... So am I legal without the sill bar?
Ryan K.
Unless an O.E.M. frame rail is located below and outside of driver's legs (i.e. '55 Chevy, '65 Corvette, etc.) a rocker or sill bar, minimum 1 5/8-inch (41.2 mm) x .083 (2.1 mm) CM or .118 (3.0 mm) MS or 2-inch x 2-inch x .058-inch (50.8 x 50.8 x 1.5 mm) CM or MS rectangular, is mandatory in any car with a modified floor or rocker box within the roll cage uprights (excluding six square feet of transmission maintenance opening).
Ryan K.
If you tack in the main hoop, then install the front bars and windshield bar, you can break the tacks on the main hoop and tilt it back and weld the rest up so you don't have to remove the windshield.
Then you weld in the door bars and behind the seat bars.
Just a suggestion for people who don't want to pull the windshield.
BTW what's the ary morrison kit go for and do they have bent over the seat bars?
Last time I read thru the NHRA rulebook, sillbars are ONLY required on unibody cars IF the floorboards have been modified
