just how fast ?????
just how fast ?????
2000 z28 with 370 inch ls1 , ported 317 heads , Speed Inc TU1 cam , eagle rods ,diamond pistons , ls6 intake , 83lb injectors, truck manifold turbo kit with a turbonetics t76 , air to air intercooler , 400 turbo with transbrake and yank 3000 converter, moser 9 inch with 3.25 gears , weldon fuel pump with nasty performance fuel tank and braided lines , fast xfi with xim fuel injection , umi suspension ,, weld pro stars , aerospace brakes front and rear , qa1 coilovers on front and qa1 shocks on rear . too much to list
car went 6.09 on 325/50/15 drag radials leaving with 10lbs of boost with around 15-16 lbs total boost with 60lb injectors .
car should run in the 5s with more boost with the bigger injectors and more boost
so what do you guys think thi scombo is actually capable of in the 1/8 mile
I say 9.4 in the 1/4 mile.
Its my old car Guys.
Turn the boost up. Let it eat. Hell a T4 PT88 will drop right in. I had one on it during mock up. That would really wake the car up.
I dont think getting deeper int he 5's int he 1/8 will be that hard with it current setup. A little more boost and some suspension tunning should be all it needs.
