Drag Racing Tech
1.2x 60" Footbrake guys!
Old 02-07-2008, 05:17 PM
TNTaddict's Avatar
Default 1.2x 60" Footbrake guys!
i'm runing Eibach prokit springs in the back and QA1 275lbs in the Front and ran abest of 1.29 60",,,and i'm thinking of the Drag launch Springs,,,what are u guys runing in the back?
and one more Q about Travel limiters as i just installed them after i couldn't keep her nose down...do you still adjust it the way it was befor the tarvel limiters?
thx in advance..
Old 02-08-2008, 03:02 AM
TNTaddict's Avatar
anyone!
Old 02-08-2008, 09:08 AM
FASTFATBOY's Avatar
1.20 60 foot.....I WISH!
You best leave that thing alone, you might mess up a good thing.
David
Old 02-08-2008, 10:56 PM
Jantzer98SS's Avatar
I have the eibach front drag springs if you want to try them. PM me.
Scott
Old 02-09-2008, 03:10 AM
1dirtyZ's Avatar
jantzer, don't think he could , check out his location
TNT , less talk and get your *** to the shop and get that thing finished !! ( and post up the pic of the 1.29 launch!! )
seriously, from looking at the car launch you can tell it needs to keep the nose down a bit more. how much will it hurt / help the car to go with limiters??
Old 02-09-2008, 09:46 AM
TNTaddict's Avatar
Old 02-09-2008, 01:39 PM
jmill96Z's Avatar
I'd be happy with a 1.3 footbrake 60'.
Old 02-09-2008, 01:54 PM
kp
kp's Avatar
I have the limiters set for about 4" of travel right now but the way the car is set up now I dont even need them really. Its just something you really have to experiment with. Dont assume the limiters are a cure all for wheelstanding, I can put it on the bumper with 2" of front end travel.
I can 1.2x footbrake (or transbrake) no problem and the front tires hardly come up at all. Its a lot of juggling between spring rates, corner weights and shock settings to get the car to 60' hard on a crappy track and keep the front down on a good one. Right now I'm using QA1 Gen F 300lb spings in the front and the stock rear springs.
Old 02-10-2008, 11:00 AM
BAKED's Avatar
1.37 60' here off the foot brake with all stock front suspension, and CE shocks in the back with BMR LCA's and SFC's stock rear springs.
Old 02-16-2008, 11:06 AM
Lythropus's Avatar
KP, What are your shock settings? I need a good starting point...
