pics of your 5-point harness mounts
how did you guys mounted your harnesses? I've got the right harness and know how i will be doing my mounting brackets, just want to see how you guys made yours work thanks
to clarify, I will have the madman crotch strap bracket. Ill use the stock belt bolt holes and keep the stock seat belt bolted along with it. It looks like I may have to bend the brackets that come with the harness to bolt to the floor. I have tried bending the brackets and they are too thick for me to bend. I can get by with the bolt by the door, but the one by the seat buckle may have to be turned
If you have your belts mounted in the stock holes, you are not loading them as designed, and subsequently they will not be able to take all of their designed loading in an accident (i.e. most are rated to about 10000 or 11000 pounds of force, and as Dale Earhardt Sr. proved, if not mounted correctly they can fail under substantially less loading!).
