New housing from Burkhart
LS1TECH Sponsor
YOu beat me to it. Here are some full size pics as well as a few others of rear ends we are doing.
http://upgradeadvantage.spaces.live.com/
Chuck said you were slacking!!!
Race your car!
Nice looking piece. 5 inch chop per side, that's seriously narrowed, what offset rim is gonna get used with that, and is the car minitubbed? I've never heard of anyone going that skinny... axles have got to be nice and short, nevermind the whole thing being a good bit lighter.
How much weight savings does that get ya over a stock width rear, if the rims are the same weight?
Does the Narrowed LCA use bushings or are you running rods ends with the 5/8 bolts without bushings?
Also the LCA holes look dropped a lot more than the typical 3 hole relocation, how far down are the holes located because I am going to run a 29 or 30" tire with the fender hight at 26 1/2- 26 3/4" and it seems like it'll have to drop a lot to get the LCA angle correct.
Oh and that rear looks bad ***, burkhart makes top quality stuff
Anyways hows the car repair coming? I want to see that thing on the track, besides I still remember that video of that nitrous car guy, I'd like to see you guys whooping his *** on a video =)
OWN3D BY MY PROF!
Let me check to see if I've got this correct. I'd like to fit a 15x12 under my formula once I get it running.
-Narrowed LCA mounts from stock to?
-What size OD LCAs are you running?
-Smaller 1/2 bolt size.
-Are they relocated inwards? The old inside the mount thing?
What backspacing do you plan on running to fit a 15x12?
