Drag Racing Tech
Am I crazy with this gear selection
Old 02-19-2008, 11:00 PM
patriotformula's Avatar
Default Am I crazy with this gear selection
Ok, really wanna go ***** out this year and have a fast cam only car... Got a 9 inch so gear selection is prime. Thinking about a 4.71 on a 28 tire. With a guestimate of 3400lb vehicle (took some weight outta the front...) and a 410 hp it puts me through the trap at 6800 rpms and at 11.20 or so. I do still drive this car on the street, is that gonna be too much? I dont really wanna make it completely undrivable? Any advice?
Old 02-19-2008, 11:01 PM
ls1 joe's Avatar
I had 4.71 in my cam only car as well as a 5.0 when it was heavyer.
Old 02-19-2008, 11:06 PM
daniel6718's Avatar
dont forget to have some converter loss and/or drivetrain loss
Old 02-20-2008, 04:52 PM
Ya its a 6 speed... I think Im gonna leave myself a little room to breath and just do the 4.56 on a 28 tire. Afterall its a 9 inch so its very easy to change gears!
Old 02-20-2008, 05:00 PM
RAGENZ28's Avatar
Run the car first and see what mpg you run, then you'll have a good figure where you need to gear it, it's hard to run too much gear with a 6 speed on the street, it has a 0.5 6th gear, you could run a super high 6.0 gear and still only be a 3.0 final gear ratio.
If you're going for all out motor performance, stick a 28 or 29" tire on it with as much gear as you can run.
I plan to run 5.29's in my next rear
Old 02-20-2008, 05:08 PM
very true also... The other thing is gears are cheap... Ill try running a 4.56 if it drags me down too much I'll grab another set of like 4.71 or something
Old 02-22-2008, 10:32 AM
HAHA I 1's Avatar
I have 4.30s and wish I had 4.56s.
Old 02-22-2008, 11:56 AM
Demonicbird00's Avatar
im running 4.10s. but i also have the mn12 in the car w/ a 26" tire....so its about a 4.56 w/ the stock mn6 in there i believe
-brandon
Old 02-22-2008, 07:22 PM
Davey J's Avatar
I have 410`s and a th400 and I go through the traps at about 7000@127 with a 26 inch tire so I think you will be ok
Old 02-24-2008, 04:01 PM
black_z's Avatar
I had 4.30s in my cam only car, and ran out of gear on a 25.7" tire (119@6800) It is still great to drive on the street. I wouldn't mind a 4.56 one bit.
Old 02-24-2008, 09:17 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,096 Likes on 720 Posts
Silverghost ran 4.71's and other gears, see what he says. Fireball ran them too I think.
I would vote for 4.56's.
Old 02-24-2008, 09:21 PM
RAGENZ28's Avatar
Gear your car to run with a 26" tire, if you need more gear run a taller tire case closed.
Old 02-24-2008, 09:59 PM
JUICED96Z's Avatar
Thats an option also.
My TH-400 car has 3.73's with a 28 inch tire, nitrous car and from what I can tell its a really good match with the cam.
With a 4.71 and a 28 your gear ratio in the end will be higher. I can't remember just how much it adds but like Ragen said, more tire height adds gear.
Old 02-24-2008, 10:48 PM
Well... I wish I had the luxury to have both sets of tires to run this year... Tighter budget since Im still in school. I went ahead and got the 4.56, I think that will be a good one incase the car doesnt hook the best, dont wanna run outta gear cuz the car doesnt hook perfect. Time to put the 9 inch together and get the 28s mounted!
