Drag Racing Tech
Got a little carried away with weight reduction
Old 02-20-2008, 01:06 AM
Jantzer98SS's Avatar
Default Got a little carried away with weight reduction
I'm about 3 1/2 cuts from backhalf. Kinda careful not to sneeze.
Approximate Weights
Rear hump 15lbs
Above Tank Area 15lbs
Spare tire Area 15lbs
Opposite side of Spare Area 15lbs
Cutouts for 16" Mini-tub 40ish lbs without bumpstops
Will update as frame gets boxed in and tubs go in.
Old 02-20-2008, 03:40 AM
Some more progress pics.
Old 02-20-2008, 04:00 AM
Josh@KY-Turbo's Avatar
Dayum!!! I like it.
Old 02-20-2008, 06:22 AM
Fireball's Avatar
I have a very similar pile of wires in my garage
Old 02-20-2008, 06:24 AM
InsaneAuto86's Avatar
Nice, now where did you get a manual on wiring? I need to know what can go.
Old 02-20-2008, 06:50 AM
Fireball's Avatar
www.alldatadiy.com
can get all the wiring diagrams on there...not a fun job though
Old 02-20-2008, 08:03 AM
James Montigny's Avatar
Hardcore man ... holy ****.
Keep us updated.
Old 02-20-2008, 08:33 AM
bjamick's Avatar
WOW man that car should be light as hell..
Old 02-20-2008, 09:03 AM
dlove's Avatar
what is you race weight goal?
Old 02-20-2008, 12:17 PM
Taubr Unit's Avatar
WOW, thats all i can say!! I like it though, im a fan! MORE PICS PLEASE!!
Old 02-20-2008, 12:24 PM
Race your car!
JL ws-6's Avatar
I HAD a pile like that, before I chucked it all.
That's a serious shop though, I'd guess the only reason the car isn't getting back 1/2'd is to be able to race in a stock suspension class.
Old 02-20-2008, 12:26 PM
2800lbs. but it might come in closer to 2900, not sure. I didn't weigh the car before I started. But I'm over 300lbs lighter than before and it was no heavy weight. I plan to run the stock dash (gutted) and door panels so it looks someone like factory. I cut every bracket off the car that wasn't being used. I also spent about 2 weeks removing undercoating and paint underneath. It's all POR'd now. It was a lot of work for only 10lbs of undercoating. But 10 here and 10 there is well over 300 now.
That is a crapload of work to cut those wire outs. And that pile with plenty of extra fuses and crap was only 10-11lbs. I did keep power windows, doors, mirrors, all my lights including mirror and some other stuff. So I could have got alot more. To be honest, it may have been cleaner and easier to start over with a new painless harness and relay box and just reuse the engine harness.
Cutting the dash cowl back like I did and boxing it in only saves 5lbs FWIW.
Old 02-20-2008, 12:34 PM
I think you mean serious "chop". But in any case, it's in my buddy's garage. I've been sick and staying with my brother, but if it wasn't for them I wouldn't get to work on it. Oh and they're helping me.
You are correct, I didn't back-half so I could run stock suspension if I want. I might relocate the LCA and if I do I think I can stuff any size tire I will need in there. I'm thinking 29 10.5, but have 325/50/15's now. I will probably be narrowing the rear-end here shortly.
Old 02-20-2008, 12:39 PM
kp
kp's Avatar
Hey man, sixteen 1oz little things = a pound One day I'll be doing the same thing..
Old 02-20-2008, 12:48 PM
DopeFedZ's Avatar
My pile of wires was looking the same then I got frustrated so I just yanked it all out. I'm just gonna go with a painless harness.
Old 02-20-2008, 12:57 PM
Thats what I was thinking exactly when I took the stock CD player and gutted it and just put the face back in to fill in the hole. Looks factory but weights nothing lol.
Some more pics.
Cleaned up wiring. Computer being relocated underdash passenger area.
Kirkey's - only 3.5lbs lighter for both seats after swiss cheese.
All them dang rivets drilled out to get the rear seatbelt mounts off.
Passenger side Mini-tub rough cut
One of the tow rig. (Still dialing it in) 6.0 w/ported heads, cam, 4l80e, 14 bolt rear w/4.88's. My first car and had her new since 92.
Old 02-20-2008, 01:01 PM
I may end up doing the same at some point. Just not sure I have time with everything I have left to do and get this thing going by the end of april. I originally was pretty intimidated by the wiring, but I learned enough now I could probably wire the whole car.
Old 02-20-2008, 01:17 PM
Race your car!
JL ws-6's Avatar
Will the factory wiring harness reach inside to support moving the computer inside the car?
Old 02-20-2008, 01:21 PM
Fireball's Avatar
Since there are quirky things like daytime running lights, etc, I did the same thing as you and just modded a stock harness...wasn't sure if it would be any easier doing a painless unit. Though I went a bit further and moved that entire harness inside the car
Old 02-20-2008, 01:22 PM
Yes.
What I did was run the wires that go along the passenger hood area down the passenger frame rail, then up through hole where the wiring goes through. There is barely enough room, but there is enough room. And then I shortened all the wires inside that I could.
Quick Reply: Got a little carried away with weight reduction
