Anyone make block off plates for unused areas on the dash?
Does anyone make block off plates (like a radio and A/C delete plate) to match the dash? That is the only thing keeping my from pulling the head unit and HVAC controls is the unsightly holes that would be left there.
The Bull
Re: Anyone make block off plates for unused areas on the dash?
I just cut a piece of aluminum to fit and sent it out to get anodized black. Should look fine when it gets in. It's easy to do, just need to get a small plate of aluminum and cut it up. The edges can be rough because the dash bezel will cover them up.
1 Post
I just made my own panel for the AC switch hole using aluminum sheet metal and painted it black myself. You could do the same for the radio if need be. I still have my stock radio installed.
I'm using the panel for the AC as a switch panel. Right now I have my line lock mounted there.
Lee
Lee
i made my delete plates(as well as a couple others) from plastic. its the same texture as the dash as well. ill send you a pic.
I used some generic ABS plastic for mine...
You should be able to pick some up from a car stereo install place or a local hobby shop...
IMHO, the ABS plastic looks a lot better than painted steel or aluminum.
What about using brushed aluminum and clearcoating it? I was thinking about doing that as a trim for the inside of my car. Anyone have pics like that?
I didn't know this many people were so hardcore. Sweet! ROB'S SS is hooking me up. Thanks a lot man!
ooooold thread but, i just made one this weekend. Can't hear the radio over the exhaust anyway. This will be the new location for the boost & fuel press gauge and the switches. I think it will look better than it does right now.
Its pretty straight foward. You will need 2 people to do it though. Just start unbolting things and it starts to fall out. There is 1 bolt you need to get to from under the hood for the hvac unit to come out and youll need to unbolt the 2 bolts from the steering colum and drop it down a bit. Other then that just go at it. Took me about 2 hours.
