Weld Wheel 2.0 center sections - LS1TECH
Thread Tools Search this Thread
Old 03-29-2008, 05:14 AM   #1
K9Kev's Avatar
Default Weld Wheel 2.0 center sections
Anyone know what to torque the removable centers on the Welds to when you take them off and go to put them back on??
K9Kev is offline   Reply With Quote
Old 03-29-2008, 08:42 AM   #2
DopeFedZ's Avatar
The three times I removed my centers for powdercoating I just tightened them as good as I could. Never had any probs with them.
DopeFedZ is offline   Reply With Quote
Old 03-29-2008, 10:47 AM   #3
gator's 99TA's Avatar
i called weld and they told me. i dont remember. i used locktite on each bolt as well.
gator's 99TA is offline   Reply With Quote
Old 03-29-2008, 11:42 AM   #4
csjta2's Avatar
Weld told me 27 ft. lbs
csjta2 is offline   Reply With Quote
Old 03-29-2008, 12:00 PM   #5
K9Kev's Avatar
Thanks guys, I appreciate it.
Old 03-31-2008, 10:18 AM   #6
If you leave the rim shells out in the direct sunlight for an hour or so before hand it helps(they grow slightly and the center fits the flange easier, especially if thee flange has been built up with powdercoat or anodize.) Make sure this flange area is smooth and doesn't have too much paint build-up. Use a dot of red locktite on the threads start the bolts and tighten around the wheel(like a cylinder head) in a star pattern in about three progressive pulls to keep the center from getting cocked, and finish around 26-27 ft. lbs. Don't just throw them in there and hope there OK. Too much riding on them.
jjordan is offline   Reply With Quote
Old 03-31-2008, 10:45 AM   #7
DMH Fabrication's Avatar
I asked the same question on my alumastars:
http://www.ls1tech.com/forums/showth...445&highlight=
DMH Fabrication is offline   Reply With Quote
Tags
center, removable, weld, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
