Did a search....need info on Strange rear brakes - LS1TECH
Thread Tools Search this Thread
Old 03-29-2008, 06:35 PM   #1
TS6
Default Did a search....need info on Strange rear brakes
I want to put some drag brakes on the rear of my Camaro before racing it, I just don't trust these ground down calipers I have. I've done a search and read all about the strange and aerospace brakes. I have Aerospace fronts now. I know I will have to change the caliper bracket, which usually requires removal of the axle and bearings. I read the Strange bracket can be installed without removing the bearings. I don't mind just cutting the stock bracket off to avoid pressing the bearing off and on. So if I cut off the stock bracket, do I still have to remove the axle to swap brakes? Would I have to change anything else to do the swap?
I have a Strange 12 bolt rear BTW, nothing special as far as I know.
Also, where can I get the Strange setup?
TS6 is offline   Reply With Quote
Old 03-29-2008, 06:44 PM   #2
chuckyt1's Avatar
I am in the process of putting Strange dual caliper brakes on. You do have to remove the axle and yes, I cut my stock backing plates off. Also, with the setup I am using, I had to get bearing spacers that move the axle out about an 1/8th of an inch. I got mine from Madman. They go in the axle tube behind the bearing. This is on a 9 inch...
chuckyt1 is offline   Reply With Quote
Old 03-29-2008, 06:48 PM   #3
kp
kp's Avatar
I just cut the stock brackets off mine when I did the strange rears so I didnt have to press the bearings off. You have to use a spacer between the axle bearing and housing when you use the strange brakes so the axles need to come out so you can put the spacers in. Lot easier to cut the stock brackets off with the axles out as well.
kp is offline   Reply With Quote
Old 03-29-2008, 07:00 PM   #4
TS6
I know this seems newbie-ish, I've just never dealt with a C-clip elim. type setup like mine.
So I just undo 4 bolts at the axle, slide the axle out (after removing the caliper and rotor), cut off stock bracket, slide spacer on and slide axle in with new bracket and put on the new caliper/rotor? Will I need to replace any seals?
I was told I could just do one side at a time and lift the car so that the fluid goes to the side I'm not working on.
Who sells the Strange setup?
Old 03-29-2008, 07:07 PM   #5
studderin's Avatar
ya, should be just like that.
I know the the stange s60s you done lose any fuild with the fornt on the tires, and the rear on stands. The axle seals hold the fuild in fine.
studderin is offline   Reply With Quote
Old 03-29-2008, 07:10 PM   #6
TS6
Well, since I won't really be under the car I can just lift one side at a time. I'm not cheap, I just REALLY hate diff fluid. Its the only automotive fluid that bothers me and I JUST changed it like 50 miles ago.
Old 03-29-2008, 07:26 PM   #7
chuckyt1's Avatar
Don't know about the 12 bolt but, I have my 9 inch up on stands and both axles are out. No fluid leaking...
Put the spacers in the housing and then put the axle in.
I think Burkhart might sell em. A sponsor...
Old 03-29-2008, 08:56 PM   #8
kp
kp's Avatar
madman has the spacers too.
Just take the four bolts out, most likely it wont just slide out. Turn the brake rotor around, slide it on the studs, put three lug nuts on and use the rotor like a slide hammer to yank it out if they are stuck. Even level very little fluid will come out, but on an angle nothing will come out except whats clinging to the axle.
Old 03-29-2008, 09:03 PM   #9
TS6
Quote:
Does he sell the brake kit too?
Summit? Jegs?
Part number?
Old 03-29-2008, 09:20 PM   #10
kp
kp's Avatar
Quote:
Summit? Jegs?
Part number?
I dont know, you can just call strange, thats where I got mine from. Same price as everyone else was selling it for.
But one of the vendors can hook you hook you up with the correct hoses, spacers and brakes all in one shot..
Old 03-29-2008, 10:33 PM   #11
LS1Tech Sponsor
MADMAN's Avatar
Call me I can get you the brakes and a Burkhart lione kit plus the correct spacers. 225-673-3533
MADMAN is offline   Reply With Quote
Old 03-29-2008, 11:43 PM   #12
TS6
You around tomorrow by chance?
Old 03-30-2008, 12:11 AM   #13
DMH Fabrication's Avatar
PM me a price on the dual strange rear brake set up when you get a chance Brian.
When you install the spacer and move the axle out 1/8" does that in any way negatively affect the engagement of the axle splines into the center section? I would assume there is enough spline engagement that the 1/8" does not matter.
DMH Fabrication is offline   Reply With Quote
Old 03-30-2008, 10:07 AM   #14
TS6
No, it doesn't affect it. I'm actually going to have my rear narrowed and Strange said they could take 1.25" off each side w/o changing axles, since they could cut that much off the splined end and still be OK.
Old 04-03-2008, 06:25 PM   #15
Do you need the above mentioned spacer if you already have a spacer on the axle? With the LT1 rear brakes Moser gives you a spacer to install before you press your bearings on.
Old 04-03-2008, 07:54 PM   #16
LS1TECH Sponsor
Steve Burger's Avatar
If the spacer is between te housing and baring you are good to go. This spacer pushes the Axle and Bearing out.
Steve Burger is online now   Reply With Quote
Old 04-03-2008, 09:34 PM   #17
Black Sunshine/ 00SS's Avatar
So this would push the tire out further from the LCA?
Black Sunshine/ 00SS is offline   Reply With Quote
Old 04-04-2008, 08:31 AM   #18
LS1TECH Sponsor
Yep about .1".It pushes te bearing into the caliper bracket. Not even enough to worry about.
Old 04-04-2008, 11:53 AM   #19
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
I am starting to do the swap from stock rear brackes to Mark Williams racing brakes this weekend. Well, I will finish it up on Monday when Madman gets me my spacers. I will do a write up & pics on the project.
Coach
Coach 02 A3 Z/28 is offline   Reply With Quote
Old 04-05-2008, 07:08 PM   #20
Quote:
Yeah my spacer from moser measured .122".
Do you have any pics of how the brake lines work out with the dual calipers? Do you have a kit for the lines or is it easier just to build your own lines?
Thanks.
Related Topics
Thread Thread Starter Forum Replies Last Post
front brakes question renthalatvr Suspension & Brakes 0 07-13-2014 09:13 PM
Strange brake rear problems FAST Beast Suspension & Brakes 1 09-03-2013 12:09 PM
Aerospace Rear Drag Brake install vs stock WhiteLTone Drag Racing Tech 0 08-19-2013 09:25 PM
Stock brakes on a strange 12 bolt 95_transam_lt1 Suspension & Brakes 4 04-04-2012 05:39 PM
Template for cutting stock spindles for drag brakes 03 BUSA Drag Racing Tech 10 04-26-2011 09:04 AM
Tags
12, aerospace, bearing, bolt, bracket, brake, brakes, caliper, cut, delete, dual, ls1, ls1tech, rear, strange
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
