UMI Relo brackets w/ BMR LCA's
Anyone using UMI Relocation brackets along with BMR Adj Poly LCA's? If so, did you use the rear LCA bolts provided by UMI and what did you torque to?
I think the UMI bolts provided are low grade and BMR calls for 80 lb-ft. That, I think, is grade 8 bolt territory. I actally the UMI bolt shear at 75 lb-ft.
For the front bolts on the LCA's, I re-used the stock bolts and I believe torqued them to 80 lb-ft. They held up, but I'm a little worried and there's no mention in my Hayne's Manual on torque spec for the stock bolt.
Any suggestions?
Any suggestions?
dddd
Sure, but what did you torque them to? Of course they will hold up to UMI's torque rating (45 lbs). My issue is related to torquing them to 80 lbs as directed on BMR's instructions.
I'm not running LCA relocation brackets (yet), but I have 1/2"x4" Grade 8 bolts all the way around, you can get them most anywhere, although you have to enlarge the holes to a 1/2" to make them fit. (The stock bolts are 12mm.)
I did this because the bushing in my BMR LCA's is 1/2" ID.
Oh, and I torque mine to 90 ft lbs and forget them.
Just food for thought.
If I can help anymore please ask. Thank you,
Ryan
