Any ET gains from race gas at 11.1:1 CR ?
1 Post
I'm running 11.1:1 CR and currently use 93 Octane with one of those 104 Octane Booster bottles with each tank. I am able to run 29* of timing with no KR. At 30* I was getting a little KR so I backed it backed to 29*.
Anyone with 11.x:1 CR have any ET gains from running race gas? If so what do you recommend, 100, 104, 110 octane?
I'd be curious to see if I could run 30-31* of timing on higher octane...
Thanks.
Lee
Thanks.
Lee
Re: Any ET gains from race gas at 11.1:1 CR ?
I would try some 110 and bump the timing up to 31* or so. I beleive there should be some time drop there but I cannot speak from experience with ls1 vehicles( still working on my bolt on goal before I go internal)
Josh S.
Josh S.
Stu, that's only true of leaded gas. So long as it's unleaded, it doesn't matter what octane it is. Been there, done that.
Stu: 104 is the max unleaded gas you can get. I wanted to get a few gallons just to mix in when im at the track just to make sure i dont get any knocky up top Im running 30-29degrees up top also
"Stu: 104 is the max unleaded gas you can get."
Actually, VP Racing Fuels sells an unleaded called "HTG" which has a motor octane of 106. Their site doesn't say, but I would guess that would be about 110-112 octane by the R+M/2 method.
If you are having a hard time finding race gas go to motorcycle shops. Most of them have VP unleaded race gas in handy sealed metal containers.
There's another company in Canada that has a motor octane of 106 (112R+M/2)too.I forget there name but I think its millenium fuels?
I bet there's alittle hp to be had running VP103 in a 11.1CR car thats using N20/FAST system.The tuning ability of the FAST accompanied by the 11.1 could get you a few HP plus with the N20 it would be able to hit a higher shot w/o worry of detonation.
For most guys I'd agree with Steven..
Just run Sunoco 94...
Union 76 Sells 100 Cool Blue in 5 gal cans. I have ran it on hot days and my car seems to run better. Hard to say how much but I usually run 13.15 to 13.17 on hot day, this stuff put me in the 13.1 range on a 100 degree day. For information on where you can get it in your area call 1-800-345-0076
Bob
Bob
