How bad is stock suspension?
Ok I need to get this car ready to race by July. Problem is I'm way over budget right now So suspension mods are on hold for now.
So what do I absolutley need to install on this car?
I was thinking subframe connectors and a drag bar at the least.
99 Camaro SS
408ci
Th-400 with t-brake
Spohn Torque arm
Strange 12 bolt with 4:10s
325/50/15 MT radial
6 pt cage
3000-3200 raceweight
Marco
99 Camaro SS
408ci
Th-400 with t-brake
Spohn Torque arm
325/50/15 MT radial
6 pt cage
Marco
since your on a tight budget, you might consider v6 front shocks/springs and a good set of control arms to minimize wheel hop. or vice versa you could get poly bushings for your control arms and pan hard and box them all in, and then get you a set of front adjustable coil overs.
Pathological Modifier
I would say for the rear suspension at a minimum you need to relocate the lower control arms.
I am running:
stock LCAs w/poly bushings
Stock panhard bar
Stock torque arm w/poly bushing)(Relocated to the crossmember)
Stock rear springs
Relocation brackets (Home made)
I cut 1.4X 60' times and run 9.9XX...
I am running:
Stock panhard bar
Stock rear springs
I believe the rear suspension has poly bushings already.
I just need to have the car ready to race July 25,26. After that I'll do QA1s, k member, etc.
Ryan your car seems to have no problem getting it done. Gives me hope.
Race your car!
tq arm is gonna break, better replace that too while you're at it.
You didn't think you were gonna get the car done cheap were ya LOL, building a solid 10 second n/a car from a stock car, and doing a good motor/trans in the process is a solid 20+ grand. Ask me how I know.
Problem I had is my OT died and that put a big hurting on my mod money. I'm used to working 60 hours a week now I am down to 45
My goal was to pay everything I buy for this car in cash. So far I am holding myself to that, I did not want to owe any debt on modding the car. Been there done that. But I also wanted the car done right the first time.
