Drag Racing Tech
Steering Issue on Long End of Track?
Old 04-28-2008, 03:24 PM
tee-boy's Avatar
Default Steering Issue on Long End of Track?
Does anyone notice that their front tires pull hard after about the 1/8 mile at the track. It seems I have to fight the car to keep it going straight. I assume it's from the 275/17 directional treads on the front.
The track I go to was re-surfaced last year, so it can't be too uneven.
Old 04-28-2008, 04:22 PM
Race your car!
JL ws-6's Avatar
Probably the rear tires at differnt sizes. That will cause what you're talking about, if you're having a problem with the car pulling in one direction at speed.
If it's bad enough it will cause the car to launch screwy as well.
Measure the rear tires, sounds like you have a set that's not matched up very well.
Old 04-28-2008, 04:28 PM
tee-boy's Avatar
forgot to mention that rears are 275/17 true street tires
Old 04-28-2008, 05:12 PM
Race your car!
JL ws-6's Avatar
I bet the rear isn't lined up right, or your alignment in the front end is off
Old 04-28-2008, 05:43 PM
tee-boy's Avatar
might be time for a 4 wheel computer alignment. have adj panhard and control arms.
Old 04-28-2008, 07:23 PM
Race your car!
JL ws-6's Avatar
control arms are probably off. If you had relocateion brackets put on, I bet one isn't welded exactly the same as the other, that will do it too.
Old 04-28-2008, 08:49 PM
tee-boy's Avatar
yeahp, I put the relocation brackets on myself. measured the control arms to stock length. 4 wheel computer alignment should take care of that as well.
