Drag Racing Tech
what kind of times should my car run NA and juiced 100 to 75
Old 08-19-2003, 09:55 PM
RJF
RJF's Avatar
Default what kind of times should my car run NA and juiced 100 to 75
what kind of times u think it should run.O and it will be on et streets.
Old 08-19-2003, 10:01 PM
RJF
RJF's Avatar
Default Re: what kind of times should my car run NA and juiced 100 to 75
will it go 12.6 to 12.7 na im taking all the system out to
Old 08-19-2003, 10:07 PM
redsscamaroboy's Avatar
I run 12.7's in the heat without the 3.73 gears on e/t streets. You need to weight that thing,my weight w/driver is 3636 w/ about 1/2 tank of gas.
Without the system i would think you should run what you want,but you'll never know unitl you try.
I run mid 11's with a 125 shot "wet",but that was with a 1.5 60ft. Don't see much reason you should not do better with 3.73 gears .
Good luck.
Dave
