Drag Racing Tech
Drag radial air pressure ????
Old 07-30-2008, 12:40 PM
bada's Avatar
Default Drag radial air pressure ????
I just bought a set of drag radials. I was wondering what tire Pressure you run for street the drive and also for racing
Old 07-30-2008, 12:46 PM
7 Second Club
Phil99vette's Avatar
25 street, 13-19 track.
Old 07-30-2008, 07:07 PM
GueSS Who's Avatar
Alot more then you think........If it shakes on the launch, add more. It took alot for me to get over the fact that they weren't slicks but we have had as much as 20psi in them.
Old 07-30-2008, 07:21 PM
bada's Avatar
Thanks guys. I have never ran a set before. So I have no idea what I am in for. I have a good chassis that is adjustable, hopefully that will help.
Old 07-30-2008, 10:25 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Might want to post size, specs of the car, power, etc to get a better ballpark on this.
On my 370 rwhp Nova I run the 275/60/15 on an 8 inch rim. Car weighs 3500 lbs with me, and I run 25 psi on the street and 17-18 at the track. Best of 1.51 60 foot.
Derek
Old 07-30-2008, 10:45 PM
phoenix's Avatar
18 psi on my 325/50R15 worked best for me
Old 07-30-2008, 10:48 PM
CamaroRacing12's Avatar
16psi-18psi for me 275/50/15's
Old 07-31-2008, 06:18 AM
bada's Avatar
I have 12 inch rims, tires are 345/55/15s and the truck is 2700lbs. ZO6 LS7 505hp. Hope this helps.
Old 07-31-2008, 08:29 AM
8secbusa's Avatar
On great track prep days I run 25-30psi and get great mph, on normal days I run 15-18 and lose 1-1.5 mph, on bad days I run 13 and lose 2mph.
275x50 MT drag radials- 1.54 60ft
The following users liked this post:
fucter (06-17-2021)
Old 07-31-2008, 09:38 AM
LS1Tech Sponsor
Indukted1's Avatar
275 60 15's 25 on the street and 10-12 at the track 1.56 60 ft's
Old 07-31-2008, 10:15 AM
daniel6718's Avatar
another question kinda still on the subject...what air gauges are yall using to check this...ive got a cheap digital one...and checked it with an few old school ones and it was differant, but its the same as the o reilley little circle one....
id like one that ready like 1/4 psi, big round gauge..0-30psi
my 255/50/16 likes 17-18...havent figured out the other sizes yet
Old 07-31-2008, 02:04 PM
gator's 99TA's Avatar
quoted for truth. i have gone down to 15 psi and shook the crap out of them. i moved it up to 20-21 psi (on the 275/60 and 325/50 m/t radials) and instantly went down to 1.3 60' times.
Old 07-31-2008, 09:25 PM
1cdub's Avatar
track prep at KCIR is pretty consistent....with my 295 Hoosiers 17-18 seems to work great...1.29 60' off the footbrake in a 3350 lb car.
Old 07-31-2008, 09:39 PM
tee-boy's Avatar
Best answer. Go to the manufacturer's website and look under their FAQ or Tech Bulletin. If you can't find anything there, call them.
MT has a Tech Bulletin which answers your original question. You can also send them an email with technical questions.
Old 08-01-2008, 01:35 AM
BOLO's Avatar
I think the majority here is 16-18 psi.@ the track. Mine always work @ 18 psi.
Old 08-03-2008, 11:38 PM
dnkynrbk's Avatar
17 to 19 here 1.42 60ft 3600 lb car with stock k member and front bumper supports
Old 08-04-2008, 04:47 AM
chrs1313's Avatar
1.40 60fts here and i have 20psi street and strip...
Old 08-04-2008, 12:24 PM
omcar's Avatar
Question: what rpms are you guys leaving at??
Old 08-06-2008, 11:34 AM
Retired Street Racer
Matt D's Avatar
18 psi hot. 1.39 60fts on drag radials with boltons.
Old 08-06-2008, 12:13 PM
BAKED's Avatar
18 psi works for me.
Quick Reply: Drag radial air pressure ????
