Drag Racing Tech
How many of you are on 10 bolts?
Old 08-15-2008, 03:38 PM
drewwrxrogers's Avatar
Default How many of you are on 10 bolts?
Who are the really crazy bastards in here running the stock 10 bolts still? I would like to know mods, times, 60fts, m6 or auto, Stall size, rwhp, and number of passes on 10 bolt. IF you are one of the lucky ones that have made their 10 bolts last.....how do you launch?
Everybody has heard so many stories about how it seems that the 10 bolts sometimes do well for a while and even more stories on how trashy they are...show em....I'd like to see some proof haha. Crazyness!
Old 08-15-2008, 06:03 PM
speedshifterNC's Avatar
headers/gear, 7.80 1/8th, 1.7 60',m6, 325hp, 10 passes
On street tires I launch @ 2grand side step, let out, get immed. back in on 20-24psi
On drag radials I launch @ 3 side step (1.8), @4 (1.7) on 14-16 psi
The most important thing when you side step @ 4 grand is to cringe and hold it to the floor..yea my 10 is coming out soon..lol
Old 08-15-2008, 07:56 PM
kdavis's Avatar
i hit 1.60 ft on the motor with stock internals. a few bolt ons and a circle d converter. still taking the beating. it does have moser axels tho
Old 08-15-2008, 08:47 PM
TravisA's Avatar
4l60e, 4k Edge converter, 400+RWHP LT1......
60ft - 1.65
1/8th- 7.28@96mph
I've ran about 10 passes on it so far.... I just flash it from idle.
Old 08-15-2008, 09:29 PM
chrs1313's Avatar
probably 100 passes in the 1.4s-1.5s range...info in sig
Old 08-15-2008, 11:10 PM
mchdg86's Avatar
tr224 cam, TSP 5.3 heads, 377rwhp, 3600 stall, 1.65 sixtys. I have made about 30 or so passes on that set up.
Old 08-16-2008, 12:25 PM
tacklebox's Avatar
413 rwhp, M6 on stock clutch, stock rear. Low 1.8 60' times feathering the clutch will get me a high 11 second pass at 118-119 mph assuming i don't miss a shift.
Old 08-17-2008, 05:33 PM
Detroitmuscle's Avatar
4K Yank with MS3 and ETP heads making cose to 400rwhp and bone stock 3.23 rear with at least 50 passes and I launch it hard. 1.63 60' is my best and several other 1.6s I've even flashed it off idle and it has dead hooked before.
Old 08-18-2008, 09:01 AM
Unstang's Avatar
3600 stall, 3.73s, 420 rwhp, MT radials, flash the converter from about 1500 RPMs. I've cut a best 60' of 1.51 a couple times on my current set up.
Old 08-18-2008, 10:53 AM
Silver_TransAm's Avatar
I am still running the 10bolt but with 3.42 gears and TA performance cover and have made over 500rwhp. I have raced at the track a couple of times and have managed a 1.8 60ft on street tires, but i have run ET slicks with 15psi in the tires. Parts in sig say the rest. Oh and I usually brake stall it to 2200rpms.
Old 08-18-2008, 11:35 AM
WOWOWOWOW
Old 08-18-2008, 06:37 PM
Sounds wicked, whats it typically run with that kinda 60'?
Old 08-19-2008, 04:18 PM
SSmoken's Avatar
3200 stall / 100 shot / 3.73's - 11.64 @ 115mph 1.7 60ft. 124k mile STOCK 10 bolt. ive added a few more things to the car since then but havent made any passes yet. Hopefully will go low 11's
Old 08-19-2008, 04:22 PM
j99fbody's Avatar
119k stock 10 bolt, 373s, 4000 stall, 11.37 1/4 mile and 7.22 1/8th, 1.55 60ft on Mt Et drag slicks and have been down the track several times
Old 08-19-2008, 07:51 PM
that firebird is bad
Old 08-19-2008, 08:02 PM
95 Z28's Avatar
I went 1.81 on my bone stock 3.42 geared rear end. M6 with 395rwhp. I usually just launch like a bitch and get 2.0s though.
Old 08-19-2008, 10:19 PM
Havok2's Avatar
1.54-1.56 is my avg 60 ft
cam only (mild) small 3400 stall mickey ts drag radials.
11.46 is my fastest on cam only/bolt ons
stock 10 bolt. 373 gears with ta girdle, stock axles.
Old 08-20-2008, 05:52 PM
LS1HIGHLIFE's Avatar
00 Camaro Z28 M-6, H/C/I/E, SPEC 3 with fidanza alum flywheel
11.80@119 with 1.82 60' on 10bolt with 3.73 and MAC girdle, Weld prostars with Hoosier 27x11.5/15 QTPs
433/383 rwhp/tq
I'm made quite few passes on her over the years. A lot of side stepping but here lately I've been letting the clutch out easy at 4K and have gotten a best of a 1.82 60'. I know I can get better ETs but I would be putting my rear in much more danger. I don't have the dough for a 9".......
Old 08-23-2008, 08:40 PM
1baddroptop's Avatar
1.63\ 1.59 60ft 7.74 1/8 mile pulled driver side tire 6 to 8 inches 435rwhp weighs 3820 and it is a convertable but so far so good i've got about fifty passes on stock 10 bolt with 373 gm gears
Old 08-25-2008, 10:15 AM
nunleysz's Avatar
somethin smells fishy!
Quick Reply: How many of you are on 10 bolts?
