What to do with heater core send/return lines ?
I`m removing the HVAC system from my car. What do I do with the heater core send return fittings on the water pump? Do you just loop them? If so, whats a good way to do it being that they are two different size fittings?
Thanks.
Thanks.
Re: What to do with heater core send/return lines ?
I went to Pep Boys and bought a 3/4 and 5/8 bypass cap. Thet are rubber cooling caps that slip over the barbs and just clamp them on.
Super Moderator
I was thinking of just looping it also but you would have to adapt for the size difference and I would think that adding some kind of coupling would create a possibility for leaks. Seems like capping the fittings at the pump would be the way to go.
I don't think the differant sizes would cause any problems. Just use the larger of the two hoses and clamp them good. Should take up any slack.
LS1TECH Sponsor
Any cooling differences by just capping it off and not removing the thermostat?
I read that the lines should be looped to help open the thermostat at the correct time.
