VHT + Drag Radials?
has not failed yet! you can really tell the difference on the street...
of course only if applied correctly. some people want to do a Warren Johnson burn-out using VHT,just do a small burn-out to clean the tires off then apply some VHT rotate the tires a few times in it and stage....i have had great success with it!
For the street I put it on the ground after we lay some rubber down, we mix it with some alcohol and then light it on fire. When it goes out it will pull your shoes off of your feet!
I've seen some guys pour some Coka Cola (yes the drink) on the ground and let it sit for a while then do some burnouts over top of it. And yes, it works believe it or not.
