Do I have enough exhaust? - LS1TECH
Thread Tools Search this Thread
Old 09-11-2003, 08:25 PM   #1
SPANKY LS1's Avatar
Default Do I have enough exhaust?
My new head and cam combination is G5X() cam, and AS stage 2.5 (large valve stg 2s) 5.3l heads, milled to ~11.5 to 1 compression. My exhaust currently consists of Hooker LTs, Hooker ORP, and Hooker catback. I will be installing a 3" cutout in the intermediate pipe. My question is this, do I have enough exhaust, or would I greatly benefit with true duals? I have the BMR Extreme torque arm (with the crossmember that makes true duals almost impossible), and true duals would be a major hassle at this point, not worth a 3-5hp gain, IMO. Or would I gain signifigantly in going to a 3" x-pipe dual setup? TIA, Shawn
SPANKY LS1 is offline   Reply With Quote
Old 09-11-2003, 08:34 PM   #2
CHRISPY's Avatar
Default Re: Do I have enough exhaust?
I think what you have it fine. But I would look at installing dual 3 inch cutouts in the YPipe if you have the room If not the single 3 inch cutout will work well too
Cheers,
Chris
CHRISPY is offline   Reply With Quote
Old 09-11-2003, 08:47 PM   #3
SPANKY LS1's Avatar
What about this that Nineball replied to an earlier thread I had posted:
Quote:
Don't do dual cutouts for a 346ci setup. On my old heads/cam setup I tried that (dual 2.5" cutouts where cats normally would be on an offroad Y-pipe) and I lost a TON of torque. Only gained about 2 rwhp peak vs a single 3" midpipe cutout. Ran slower at the track too
Needless to say, that setup was ditched after a week. Went back to the single setup and got my ET/MPH back.
One of the biggest LS1 mistakes I've made to date
Tony
I really don't want to cut up my Jet Hot coated y-pipe unless I'm really sure its gonna work or help me.
Shawn
Old 09-11-2003, 10:04 PM   #4
Kent1's Avatar
My vote is a true dual setup with X-Pipe--more torque and power across the board--just my 2 cents.
btw, I have true duals and would not change.
Kent1 is offline   Reply With Quote
Old 09-11-2003, 10:42 PM   #5
Moderator
John B's Avatar
Clearly at least 3" true duals with an "X"!
John B is offline   Reply With Quote
Old 09-11-2003, 11:12 PM   #6
Colonel's Avatar
I like a 3" Y into a 4" Y-collector into a 3.5" I-pipe and 3.5" electric cuttout.
Colonel is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
