Vengeance Racing 440 LS7 C5 Z06 Dyno Results/Idle Clip Inside
Old 10-15-2008, 09:12 PM
Ron@Vengeance's Avatar
Default Vengeance Racing 440 LS7 C5 Z06 Dyno Results/Idle Clip Inside
Finished this one up Monday guys. Pretty happy with the results......
Customer Car- 03 C5 Z06
Modifications Include:
Vengeance Racing 440 LS7 Shortblock- Callies Crank/Callies Rods/Wiseco Pistons/Clevite Main & Rod Bearings/ARP Main Stud Kit
TrickFlow 245cc CNC Cylinder Heads- Upgraded .650 lift springs
Vengeance Racing Custom Camshaft- 254/258 .623/.623 112+4
Yella Terra Ultra Lite Roller Rockers
Comp 850-16 Lifters
IWIS Single Roller Chain
Melling Hi Volume Oil Pump
ARP Head Studs
GM MLS LS7 Head Gaskets
FAST 92mm Intake Ported by Vengeance Racing
GM LS2 90mm TB Ported by Vengeance Racing
FMS 42lb/hr Fuel Injectors
Meziere Street Pump
ASP Pulley
Kooks 1 7/8 x 2 x3 Stainless Longtubes with ORX
DMH Dual Electric Cutouts
Corsa Catback
Textralia ExoSkel Clutch with new Hydraulics/speed bleeder
3:73 Diff
Installed/Tuned by Vengeance Racing
Compression 11.8:1
Timing 26*/Air Fuel 12.6-12.8
PUMP GAS
Final #s after a brief break in are 603rwhp/563rwtq SAE.... Unfortunately we have found the limits of the FAST intake. Map readings went from 98 to 93 from 4000rpm and up....We disconnected the intake tube and tuned speed density and saw no improvement in MAP readings. I think our customer is going to enjoy his new combo for a while and then head back over for a custom sheetmetal intake and larger TB. I am confident we can see 630s out of this combo on pump gas with the new intake and a few break in miles!!!
Dyno Graph:
Under Hood shot after our tech worked his magic!!!
Idle Clip- http://www.youtube.com/watch?v=voJ9sNN7Pnw
Old 10-15-2008, 09:25 PM
94'BLKBRD's Avatar
Impressive numbers Ron.
Old 10-15-2008, 09:34 PM
ProjecT 9's Avatar
That is VERY clean looking! Nice job!
Old 10-15-2008, 10:11 PM
Pray's Avatar
That is sick. It is amazing what the extra bore and cubes will do for a motor. Great work again.
P.S. I looked at my MAP reading and it goes from 101kpa to 97kpa. Not near as bad as this motor.
Old 10-15-2008, 10:16 PM
Kurtomac's Avatar
mine did the same on the dyno....went from 100-101 on the street to 97 kPa from 4500ish on up in the RPMs
Old 10-15-2008, 10:54 PM
SLowETz's Avatar
Not bad slick-
Old 10-16-2008, 12:17 AM
Haans249's Avatar
What do you think is the cause of the torque dip from 3K-4K rpms? I've been seeing a few vehicles lately, like one in this section, that have this same dip when using the FAST intake. Some say its over cammed, could be, not sure on this setup though, 440ci eats duration pretty well. Is it something with the fast intake? Maybe the stepped headers killing low-end torque? I would have expected at a minimum 450 rwtrq at 3K rpms, probably closer to 480 given the cubes.
Old 10-16-2008, 02:53 AM
SS DNA's Avatar
Great Numbers!
Old 10-16-2008, 07:14 AM
WHPLASH's Avatar
Thats amazing!!! Beautiful engine bay!!!
Old 10-16-2008, 09:43 AM
Pray's Avatar
My 416 has exactly the same dip. I couldn't get rid of it. I just thought it was in my tune. There may be more to it though. Either way it is only worth 10rw or so.
Old 10-16-2008, 11:14 AM
Haans249's Avatar
That maybe true, but the rwtq is what is really being affected downlow. Rwhp downlow has nothing to do with how fast you get the car moving, its all in the lowend torque.
Old 10-16-2008, 02:14 PM
Pray's Avatar
I was talking about the tq. At least on my car and my dip it would only be 10 or so RWTQ.
Old 10-16-2008, 02:22 PM
Haans249's Avatar
I got ya, I'm going to send you a PM, i don't wanna cloud the thread. Its a beautiful build!
Old 10-17-2008, 06:37 AM
venom ws7's Avatar
Like always Ron great work and numbers congrats to the owner.
Old 10-17-2008, 10:51 AM
blwn_00gt's Avatar
thats a bad ride..nice job.
Old 10-17-2008, 11:00 AM
DA GOAT!'s Avatar
Leave early to post on tech eh!!!!
Old 10-17-2008, 03:41 PM
blwn_00gt's Avatar
you wasnt suppose to see that...hahahaha
Old 10-17-2008, 11:37 PM
Moderator
JayplaySS's Avatar
Amazing Ron. You guys need to help me spec a 500+rwhp N/A (through the A6) combo that will take a 150-200 shot too. I'll be calling you.
Old 10-18-2008, 10:31 AM
52172's Avatar
very nice looking motor!! Nice numbers as well. Not the first time a fast has been maxed out at that power level. Nice to see the sheetmetal intake graph overlayed on the fast intake graph when its all done. Nice work Ron!!
Old 10-18-2008, 11:24 AM
allngn_c5's Avatar
As usual Ron, your shop puts out another successful project. Congrats !!
Quick Reply: Vengeance Racing 440 LS7 C5 Z06 Dyno Results/Idle Clip Inside
