Max Effort NA 346 Motor Begins Dyno Tuning Today
Just heard from my builder (MC Racing) in Kansas City and they have just started tuning on my max effort 346 build. I should have dyno numbers later today or tomorrow. Attached below is the mod list, this car is a purpose built drag car and will never see the street.
Lets see some input on what power and torque the car puts down. I will post up dyno graphs later this weekend. Attached below are the modifications.
TrickFlow 215cc CNCd heads - decked for 12.0 compression and race gas
PRC Gold Valve Spings (good for .650 lift)
Custon Cam - 247/251 .623/.623 113+3
Calles Forged Rods
ARP rod bolts
COMP Hi Performance Lifters
Yella Terra 1.7 Roller Rockers
Diamond forged Pistons (with valve reliefs)
American Racing 1 7/8 LT with bullet turndowns
Melling Oil Pump
NA 347 Motor
Vengance Ported 92mm Intake and TB
Custom Ram Air
Other Mods - Turbo 400 RMVB
Precision Shifter
10Pt Cro-Moly Cage
Kirkey Race Seat & 6pt Harness
Grant Quick Release Steering Wheel
Strange Front & Rear Drag Brakes
Billet Specialities Drag Wheels (Front & Rear)
S60 with 35 spline axles & spool (4.11 gears)
MT ET Fronts (26x4.5) & Rear (28X10.5)
QA1 Shocks - All four corners
Yank 4500 Stall
Custom Driveshaft
Full Suspension Mods.
Weight of Car should be 3200lbs with me in the car. Radio, Speakers, AC, HVAC, Seats have been removed.
CoopZ06
Calles Forged Rods
ARP rod bolts
Melling Oil Pump
NA 347 Motor
Custom Ram Air
Precision Shifter
10Pt Cro-Moly Cage
Yank 4500 Stall
Custom Driveshaft
CoopZ06
threw a stalled th400 and an s60 that would be a miracle i think. i'll guess 450/420 with bottom 10's assuming a good hook and a sea level track. sounds like it's gonna be a beast man. congrats
Max effort w/ 12:1, hydrolic cam and an off the shelf intake?
I know a guy down in Gardner KS with a 15:1cr 347, low tension rings, perfessionally ported TFS heads, single plane intake, HUGE (.65x lift) hydrolic cam and custom 12" collectors off 1-7/8s LTs with turn downs. I wouldn't even call that "max effort"!
But if you are curious he made ~470rwhp through a Neil Chance (6k rpm) converter and a TH350.
Put a sheet metal intake, solid cam, low tension rings and some trick **** in that thing and you will have your "max effort" build. Just trying to keep you on the level man.
Who spec'd the cam and did the work on the heads?
Good luck with your numbers...I'm guessing 445/412.
OWN3D BY MY PROF!
Your S60 / TH400 combo is major overkill, added weight, and more of a parasititc drive train. Why are you going to need race gas with 12:1 cr and a cam that large. I haven't plugged the numbers into a DCR calculator, but it doesn't seem like it would be too high.
TSP went 9.82 on a heads / cam engine with a ported FAST intake. Constructively, I'd run a TH200 or light weight TH350 with billet pieces and a MWCP Fab 9. If you'd also like to take more weight out of it I have my 93 link in my sig. I've taken 307 lbs of useless crap out so far not including the AC, PS, two stock seats, and things of that nature.
The s60/th400 car is a whole can of overkill.
1 Post
Well I am not sure what you will dyno, but your combination will make some pretty decent power, and it will be able to take the abuse of MANY runs down the 1/4 mile. Best of luck on the dyno, and better luck at the track. Lets see some 10 second passes when shes done !! Don't take the comments on here personal, sometimes ls1tech can be a rough place. Again good luck !!
