torquer 3, 427 hp through a 9" with 4.11s
Old 02-13-2009, 10:24 AM
Jimmard's Avatar
Default torquer 3, 427 hp through a 9" with 4.11s
Finally got my car to the dyno to get it tuned yesterday after fixing some vibration problems I was having. Apparently I got a bent moser housing straight from moser... Anyway it put down 427hp, but the tuner said he wanted to fatten up the a/f a little bit just to make it a tad safer, so I walked out with 418hp and 377 torque.
Tuned by Charlie at RPM Motors Inc in Santa Clarita, CA
Mods:
American Racing 1 3/4" headers, catted 3" ypipe, open cutout, stock slp dual/dual exhaust
torquer 3, slp pulley, stock slp blackwing lid, k&n filter, stock untouched ls6 intake, stock untouched throttle body
textralia oz700, viper output shaft t56, pst aluminum driveshaft, moser 9" with 4.11s
I was very happy with the numbers . I was honestly hoping to break 400 since I know I have a pretty beefy drivetrain. I took it to the 1/8th mile yesterday and was able to cut a 1.70 60' bogging really bad, but couldnt get it to shift after that. I need to bleed the clutch and I should be good to go for next week. I think it has mid to low 7s in the 1/8th at 93 or 94 mph. We shall see.
428rwhp dyno video:
dyno: http://s81.photobucket.com/albums/j2...t=M2U00080.flv
first track run: http://s81.photobucket.com/albums/j2...t=M2U00089.flv
second track run: http://s81.photobucket.com/albums/j2...t=M2U00090.flv
Old 02-13-2009, 10:27 AM
PewterScreaminMach's Avatar
Wow, strong as hell with those drivetrain mods. If they're accurate, I don't think 93-94 in the 1/8 is unreasonable. I run 92 in the 1/8 with 400/367 through pretty much the same drivetrain and cutting low 1.6 60s, so your extra 20rwhp and 10rwtq should help assuming the curve looks good. But I also have a 3,650 race weight, not 3,750.
Then again, that 92mph is at Lebanon Valley, which pretty much sucks. I'd probably hit 93 or MAYBE 94 down at Etown or Atco.
Old 02-13-2009, 10:37 AM
Jimmard's Avatar
Yeah my car is a fatty. I'm also running a lowered street suspension, koni SA shocks, eibach front springs, DMS rear springs. I'd be happy if I could cut 1.6 60s on that suspension.
Old 02-13-2009, 10:54 AM
What tires are you running? I'm cutting 1.62s to 1.64s on a 26x10.5x16 ET Street. Also, what gearing? I've got 4.10s with an MN12 trans (shorter geared). The gearing helps me off the line but also kills my traction. Those 60s are with the tires spinning and launching around 4500-5000. If I could launch at 6000+ like I want to and hook, I'd be pulling 1.5s no problem, but I'm gonna need some more suspension for it to hold.
Old 02-13-2009, 10:58 AM
Jimmard's Avatar
26x11.50x16 ET streets, 4.11s with a stock camaro t56 with the viper output shaft
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Nice numbers cam only through cats and heavy drivetrain! What intake manifold is on the car out of curiosity?
How do you like the street manners of that camshaft for others wondering?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-13-2009, 11:24 AM
Jimmard's Avatar
Stock untouched ls6 intake, stock untouched throttle body.
The car was a pain to drive untuned in LA traffic especially. It would buck and surge in traffic if I didnt drive it just right. It would stall once in a while, but I was usually pretty good at doing the brake/gas at the same time to keep it going. After the tune the surging is completely gone as well as the stalling problem. When I close my cutout I can barely tell that it is even cammed.
Here is the track video, I early shifted 2nd and missed 3rd and ran a 7.85 at 85mph.
I posted the 428rwhp dyno video in my first post
Old 02-13-2009, 11:30 AM
You doing a second gear burnout and really heating those tires up? No reason those tires and that power with 4.11s shouldn't be hitting consistent 1.6 60s. Keep us posted!
EDIT: just reread it. Bogging will kill your 60' like that. What are you launching at? You nail the launch and 1.6s will be no problem.
Old 02-13-2009, 11:35 AM
Jimmard's Avatar
The first run I made was my first pass ever on a slick tire. I had about 20psi in them and I dont think I warmed them up enough, launched too high and spun a bit. The 2nd run I had them at 17psi and I heated them up good, launched at a little lower rpm and bogged. I posted a few videos in my first post. And yes that is a 2nd gear burnout
Old 02-13-2009, 11:37 AM
The first run I made was my first pass ever on a slick tire. I had about 20psi in them and I dont think I warmed them up enough, launched too high and spun a bit. The 2nd run I had them at 17psi and I heated them up good, launched at a little lower rpm and bogged. I'll post that video up in my first post too.
Cool. I've gotten my best results from about 16psi hot and launching around 4800 or so. Anything 5000+ and it kills the tires (first gear is REAL short with this transmission). Anything below 4500 and it will definitely bog unless you slip the clutch enough to fry it quick. Are you running the Z-grip or X-grip Textralia? Don't be afraid to beat the hell out of it; it can definitely handle it. And absolutely do a nice long second gear burnout. First gear is pretty much a waste of time on slicks with 4.10s.
With your extra inch of width and slightly longer gearing than me, I don't see any reason why you can't launch at 5000+ after a long second gear burnout with a REAL quick clutch release. If your suspension is setup right, it should hook and get you the hell out of there fast. I'd be looking for some 1.5 60s if everything is tweaked right.
Can't wait to hear some more results when you get it to the track next!
Old 02-13-2009, 11:43 AM
Jimmard's Avatar
It is a Z grip and I always do a 2nd gear burnout with the short 4.11s. I'll get in some good burnouts next time out after I get my clutch issue resolved. Hopefully I dont need a new clutch, mine has about 20,000 miles on it...
Old 02-13-2009, 12:27 PM
Jimmard's Avatar
dyno video up now...
Old 02-13-2009, 06:24 PM
venom ws7's Avatar
Great numbers man Congrats.
Old 02-13-2009, 07:25 PM
Johnnystock's Avatar
Wow, great numbers man with the heavy drivetrain! Congrats!
Old 02-15-2009, 04:42 AM
BayAreaSS's Avatar
Those are really good numbers. Congrats
Old 02-15-2009, 01:50 PM
LS1-NAVY's Avatar
wow im looking at close to your same setup makes me want that cam more.
also did you get the 111 or 112 lsa
Old 02-15-2009, 02:59 PM
01SOMZ28's Avatar
i'm also looking at the Torquer 3 and i'm reeeaalllyy hoping that i'll be at 400hp or more
Old 02-15-2009, 03:43 PM
Datzneat's Avatar
Nice numbers!
Old 02-16-2009, 03:54 PM
RJB01camaross's Avatar
Great numbers!!!!
Old 02-16-2009, 06:38 PM
Jimmard's Avatar
Thanks everyone! The cam is on a 111 lsa. I will try to get the dyno sheets up soon.
Quick Reply: torquer 3, 427 hp through a 9" with 4.11s
