Stock 241 Heads - 425 rwhp - 175 shot - 595 rwhp
Old 04-04-2009, 04:06 PM
ineedashortblock's Avatar
Default Stock 241 Heads - 425 rwhp - 175 shot - 595 rwhp
I just had my 2000 Camaro SS dynoed today.
It has a forged 347, slightly higher compression ratio... around 11.5
FM14 Cam, full bolt ons, 6 spd car.
Even with the 12 bolt rear end, 4.11 gears and Heavy spec 5 clutch and flywheel, it put down...
Dyno numbers
425 rwhp / 400 rwtq - Motor
100 shot - 526 - 559 tq
175 Shot - 594 - 659 tq
It's got one lean spot.. that was causing some knock retard....
I am also out of injectors. I've got about 15 more rwhp in it once I can throw some more fuel and timing to it. Timing on motor was 28 degrees and on the 175 shot was 20 degrees.
I will have a graph posted later
Old 04-04-2009, 04:20 PM
cws T/A's Avatar
Did you clean the heads any ? I sprayed the heck out of mine with brake parts cleaner and all sorts of carbon deposits come flowing out of the int/ exh ports .
Power sounds nice , have fun with it .
Old 04-04-2009, 04:42 PM
98camaroLS1M6's Avatar
what nitrous kit?
Old 04-04-2009, 04:46 PM
NemeSS's Avatar
very strong combo.
so the heads are completely stock? no valve job, valve upgrade?
Originally Posted by 98camaroLS1M6
what nitrous kit?
HSW Sudden Impact
The heads are stock, but were washed and cleaned before being put back on the motor. The motor has about 8k miles on it now.
Old 04-04-2009, 04:47 PM
Originally Posted by NemeSS
very strong combo.
Nata, stock unported. I am looking at throwing a set of ported ls6 heads on it now to see if I can break the 450rwhp barrier on motor and the 625-640 barrier on the juice. I will be ordering 200 jets soon.
Old 04-04-2009, 06:21 PM
02SOMWS6's Avatar
with a stock bottom end and a set of decked and ported and worked over 242 heads I put 473 rwhp and 407 rwtq threw a 12 bolt with 4.33 gears and a Denny's steel driveshaft. Stock castings can make good power if they get worked over in the right hands
Old 04-06-2009, 12:34 PM
Johnnystock's Avatar
Did you upgraded the solenoids for the 175-200 shot? Because I thought the sudden impact kit was rated to 175max when I bought mine..
Old 04-06-2009, 04:43 PM
I've got the largest solenoids they offer now. They said they can easily flow a 200.
