new #'s today. lt1, 5psi boost, cam, head work
Old 04-04-2009, 08:31 PM
Camaro Jearmy's Avatar
Default new #'s today. lt1, 5psi boost, cam, head work
First time i've had the car on the dyno. I was expecting 425-440. Cam, heads p/p, intake port matched, long tubes, pro charger with 5psi, put down 483rwhp and 443rwtq...surprised me !!!
Old 04-04-2009, 09:25 PM
Arc00TA's Avatar
Whats your setup?
Old 04-04-2009, 09:53 PM
allngn_c5's Avatar
Sounds like a mild blower cam, p/p'd stock heads, boltons, and a p1sc/d1sc. Pretty decent numbers considering only 5 psi !!!
A little more boost and you will make some real power. I know you probably pullied it that way on purpose. Gotta protect the stock bottom end.
Old 04-04-2009, 11:07 PM
Abdullah's Avatar
great and strong numbers. what are your mods?
Old 04-04-2009, 11:13 PM
97 lt1, 58 k miles. p600b, stock heads p/p, stock bottom end, lt4 hot cam (not my choice) intake port matched, long tubes, msd 6al. It made this power with cutting out right at 5200 rpm, i have a thread in "forced induction" on my problem, any advice would be appreciated.
Old 04-05-2009, 02:15 PM
Abdullah's Avatar
nice mods. i think your 5200rpm power cutting out could be that you need more fuel, possibly aftermarket strong fuel pump and bigger injectors.
at 10.5:1 compression i think this is too much for forced induction, i would lower that to 9.5:1 or even to 9:1 compression.
some experts might chime in.
Old 04-05-2009, 03:44 PM
42lb injectors, the afr looked great all the way up to 6400, never leaned out at all. i think its in the ignition. Everyone is saying change the coil
Old 04-05-2009, 09:02 PM
if this car hooks on slicks...think it will go mid 10's???
Old 04-05-2009, 10:55 PM
j0n
j0n's Avatar
Weight/gears?
I'm thinking low 11s/very high 10s
Old 04-06-2009, 07:36 AM
Originally Posted by j0n
Weight/gears?
not sure on the weight, will know soon. 433's and its a 6 spd
