Want trq in a H/C 346? See results
Old 04-19-2009, 10:37 AM
PREDATOR-Z's Avatar
Default Want trq in a H/C 346? See results
Here are the results of a very streetable setup without huge cams or too much overlap.
cam is 230/228 .612/.588 110-1 LSA
Not bad for a retarded setup
Thank you rmtt
https://ls1tech.com/forums/generatio...-do-heads.html
Old 04-19-2009, 11:05 AM
djfury05's Avatar
.512?
Old 04-19-2009, 11:07 AM
PREDATOR-Z's Avatar
Typo, fixed
Old 04-19-2009, 11:23 AM
djfury05's Avatar
I was gonna say, that thing really was retarded lol haha
Old 04-19-2009, 11:25 AM
registered user
ScreaminRedZ's Avatar
Great numbers!
Old 04-19-2009, 11:46 AM
LSX Mechanic
Damian's Avatar
Not too shabby. Reverse splits do fairly well with a good exhaust setup and some compression.
Was this a Comp grind?
Old 04-19-2009, 12:56 PM
PREDATOR-Z's Avatar
Hi Damian,
Yes, Comp Cam XFI (int)/XE-R (Exht)
I've had real good results mixing those 2 lobes
Old 04-19-2009, 01:52 PM
TXZ28LS1's Avatar
sick man!! glad to see power like that with a reverse split.. so who said reverse splits are only good with stock heads..LOL..
Old 04-19-2009, 01:54 PM
Daredevil_TA's Avatar
wow thats awesome, ive been thinking of going to a reverse split myself-i saw 59cc chambers so....about 11.1 CR? an it really drives smooth with that 110 LSA? nice
Old 04-19-2009, 03:39 PM
PREDATOR-Z's Avatar
It is all in the valve events and lobe shapes.
Old 04-19-2009, 08:13 PM
ExceSSive's Avatar
59cc chambers is not 11:1, more like 11.5:1 depending on gaskets.
Old 04-20-2009, 01:00 AM
PREDATOR-Z's Avatar
It is about 11.2x, stock gasket and .050 flycut (~.65 cc)
Old 04-20-2009, 02:58 AM
studderin's Avatar
nice work, thats a good jump in compression. Do the x4 heads have a rasied floor?
Old 04-20-2009, 09:33 PM
JaSSon's Avatar
Ive been running the same 230/227 cam for years. Reverse splits work.
Old 04-21-2009, 12:08 AM
Johnnystock's Avatar
This is a damn good result with that reverse split...You should start to sell your own cam series PredZ..How much for this cam?!
Old 04-21-2009, 01:13 AM
PREDATOR-Z's Avatar
If I was back home in the US, I would. That is in the plans to keep me busy.
Nothing like a little shop to get parts at cost price
Old 04-21-2009, 10:15 AM
Old 04-21-2009, 12:40 PM
V6 Bird's Avatar
Thank you rmtt
U will never convince me that a reverse grind cam will carry power. Reverse grinds are band-aids to a setup that has issues someone has yet to find...Intake restriction, exhaust restriction etc. Find those with a normal split cam or square cam and it will make more power then reverse grinds. Keep continuing the band-aids...its making someone cheap money.
Old 04-21-2009, 01:32 PM
rmtt's Avatar
It's my car.
I had more peak HP/Tq, way more hp/tq under the curve, and mine carried longer than most of the cars that have been on the same dyno with traditional split cams (larger than mine) and name brand aftermarket heads. I know because we overlayed the graphs.
I think it carried just fine for how far we spun the engine. The graph is proof. I personally don't see my setup as having an issue.
Old 04-21-2009, 01:48 PM
V6 Bird's Avatar
Originally Posted by rmtt
It's my car.
You probably aren't going over the car with a fine tooth comb either. I could go on and on but Ill save it for the technical people who understand whats really going on in an engine when you run into an airflow wall or an exhaust wall on the dyno and how to find it with some tweaks in a tune.
Quick Reply: Want trq in a H/C 346? See results
