Texas Speed 2010 Camaro SS Long Tubes & Rumbler 5 Cat-Back Dyno Results!
Old 05-16-2009, 07:13 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default Texas Speed 2010 Camaro SS Long Tubes & Rumbler 5 Cat-Back Dyno Results!
As promised, we did not waste any time developing parts for the 5th gen Camaro! We have been ready to start the build process in anticipation of our first car arriving. Needless to say, we have been very busy the last two days. The first round of dyno results are with our new TSP 1 7/8" long tube headers and "Rumbler 5" cat-back exhaust system. Keep in mind that ALL NUMBERS PUBLISHED ARE UNTUNED! HP Tuners has not finished their beta software, so we do not expect to be able to tune for another 5 days or so. The car is showing high 11's a/f ratio, so needless to say, there will be some power in leaning it out. I'm sure the timing is set conservatively, too. The tuning will be for another day and another post.
As most have probably seen, our 390-mile SS baselined at 372 RWHP and 372 RWTQ. FYI, the car is a six-speed manual. With the addition of our prototype TSP 1 7/8" long tube headers, off-road connection pipes, and cat-back exhaust, the car gained 26 RWHP and 35 RWTQ to net 398 RWHP and 407 RWTQ! Again, these are untuned numbers. Achieving 400+ RWHP with stock induction will be a walk in the park once it's tuned. We are very pleased with the results. The headers feature 1 7/8" primary tubes with 3" collectors, and the headers will be ceramic-coated inside and out! Our TSP Rumbler 5 cat-back exhaust system will use your choice of two OR four Dynomax bullet mufflers! The system being tested on our car uses the four mufflers, and it has a great sound to it, as you can hear in the video below! Our Rumbler 5 cat-back exhaust system will be a direct bolt-on system just behind the factory cats for those wanting to retain the stock exhaust manifolds and catalytic converters. The great part is that you can start with our Rumbler 5 cat-back exhaust system, and if you decide to add our TSP long tube headers down the road, with or without cats, it will all bolt up! No cutting or welding will be required!
These are preliminary results, and we will complete our results once we can monitor what the PCM is doing. We will also complete our testing of our TSP induction system for the 5th gen once tuning is available. FYI, we will have dyno numbers in a few days testing our Rumbler 5 cat-back exhaust as the only mod, for those interested. Not only will you be able to gain some nice power from the additional flow, but you'll also shed quite a bit of weight! The factory exhaust system is NOT light, particularly the trash cans GM calls mufflers. All said and done, I think it will be very feasible for new Camaro owners to legitimately make 420+ RWHP with bolt-on modifications! We have a few other bolt-on mods in the works that we should be done testing shortly. Give it some time, and you're going to see 500+ RWHP N/A '10 Camaros roaming the streets with heads/cam packages and bolt-on mods! Our new SuperFlow 902 engine dyno will be installed next week, and then we will begin our extensive LS3 and L99 VVT testing. All TSP products will be test-proven, both on our engine and chassis dynos. We will offer proven packages with real-world results for everyone to see. Our second '10 Camaro SS will hopefully be delivered in a month or less, so we will be able to test on multiple cars to guage consistency between vehicles. It will also give us another platform to try other mods! We are dedicated to providing the best parts and packages available with proven results.
Dyno Sheet:
Quick Pics From On The Ground:
Video From Dyno:
http://www.precisionracecomponents.com/2010exhaust.wmv
Video From Startup:
http://www.precisionracecomponents.com/2010exhaust2.wmv
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 05-16-2009, 07:37 PM
Saladbar's Avatar
Nice numbers!
Track times next . In the fall of course.
Old 05-16-2009, 08:06 PM
BayAreaSS's Avatar
Thats pretty good for being untuned. 420 with bolt ons won't be to hard
Old 05-16-2009, 08:35 PM
Swift_01_z-28's Avatar
Love the new camaros. Nice numbers, and I could see 420rwhp with bolt-ons and a tune. Now if we could just get gm to get the new Z28 up and running, then you guys could play with that one.
Old 05-16-2009, 08:48 PM
CJDZ24_Z28's Avatar
Amazing!! Glad to see a GOOD company with one of the 1st waves of parts!
Old 05-16-2009, 08:53 PM
Trunion King
bene's Avatar
This is insane, 420ish rwhp with just bolt ons.
Old 05-16-2009, 08:54 PM
venom ws7's Avatar
Thats awesome untuned and still have stock induction.
I can wait for some H/C results.
Great work like always TSP
Old 05-16-2009, 09:29 PM
DoggyB22's Avatar
yea 500+ with a cam!!!
Old 05-16-2009, 10:23 PM
NHRAFORMULA00's Avatar
nice!!!
Old 05-17-2009, 07:38 AM
PREDATOR-Z's Avatar
And she was never the same again. nice results untuned, 400/400 with induction and exhaust is sweeeeet.
Old 05-17-2009, 07:49 AM
registered user
ScreaminRedZ's Avatar
Very impressive numbers! Good work, guys.
Old 05-17-2009, 08:18 AM
52172's Avatar
their at 400/400 without induction and without tune.....
Old 05-17-2009, 09:33 AM
We already have the induction, but I have a couple small tweaks to do to it before I produce final numbers on it. I need to test it on 3 cars or so before I'm happy with it. Inductions are a little bit different animal, you always want to see it repeat several times to make sure all is good.
I'll keep you guys updated!
__________________
Jason
2005 Twin Turbo C6
Old 05-17-2009, 10:02 AM
airforcemanss's Avatar
i am extemmmely picky when it comes to exhaust sounds and that is absolutely perfect!!! excellent job couldn't imagine the work involved.
i was wondering while you guys are introducing new mods as time goes by could you weigh the stock pieces? im wondering how much weight was shed with the massive stock exhaust. hopefully with replacement mods the pig can get to 36xx range.
are you guys going to be toying with a v6 version too?(not that i would buy one) but it would be interesting to see what the new gen v6 will do ya know?
Old 05-17-2009, 10:17 AM
LT194CamaroZ's Avatar
that exhaust system looks a little lighter than the factory bulky exhaust system, what kind of weight savings would we be looking at, mainly wanting to know b/c we all know that this cars main problem is how heavy it is
Old 05-17-2009, 10:55 AM
Honda Nick's Avatar
Jason,
I know you guys have really crappy D.A. in Lubbock, but do you plan on getting some 1/4 mile numbers soon?
Old 05-17-2009, 12:05 PM
lovin_myZ's Avatar
looks and sounds good guys..
Old 05-17-2009, 02:38 PM
BlkBird2000's Avatar
Nice job.
Old 05-17-2009, 08:07 PM
Johnnystock's Avatar
GM did this one right, and with the touch of Texas speed, it will become a freak!! ...LSx power!!
Old 05-17-2009, 08:23 PM
02SSLE's Avatar
Very nice.
Quick Reply: Texas Speed 2010 Camaro SS Long Tubes & Rumbler 5 Cat-Back Dyno Results!
