AFR 205/6016 cam...475 rwhp 425 rwtq
just thought i would share my results for anyone that is interested. my mods are
AFR 205's milled to 62cc and touched up by tony mamo
8019 spring upgrade
AFR 6016 cam (224/228 on a 114)
mamofied FAST 90 and LS2 TB
ARH long tubes and catted x-pipe
YT 1.7 ultralites
crane billet lifters
comp cams high tech pushrods
cometic .040 gaskets
slp 25% UDP
monster 3.5 clutch with chromoly flywheel
sorry about the huge pic.. i will resize it later when i get a chance
still had the stock air intake and mufflers when i dynoed, but i now have a haltech venom on it and a set z06 Ti mufflers on the way
8019 spring upgrade
YT 1.7 ultralites
slp 25% UDP
yeah i plan on getting it dynoed again once the mufflers show up. right now i have a set of flow matched 60# injecters in there that i got a great deal on, but i am thinking of getting some svo 30 or 42's since 60 is an overkill for my setup and my idle quality is probably suffering a tad.
I am half tempted to pick up a spare uncatted x-pipe to run and have the catted one just to throw on there for inspection day lol.
anyways the picture is much smaller now
well the mufflers have a 1.5" bypass in them like alot of guys do with the titanium ones and the air intake had the zip tie mod, but i am not sure how much that would gain
we will see when i get it dynoed again
1 Post
I am with these guys. My old 346 afr 205 g6x3 with every mod you could get only made 490 rwhp 445 rwtq, and that was on what has been proven to be a very happy dyno. Proof was in the trap speed, or lack of trap speed. 123.6 mph? Should've trapped a good bit more considering the dyno claimed 490 rwhp and 445 rwtq. See sig for my newest setup, 130s or bust !!
Guys, he's following a good bit of PatG's recipe to 500hp and the Mamo combo. He's clearly paying attention to details and it shows. Even if it is a bit of a happy dyno, this is stout for such a good mannered cam. We'd all like to see this supported with track times or another dyno, for sure. Fact is, this may be stout but it is perfectly believable. It's also in a vette, which has a much better factory intake and exhaust than the "other" LS1 platform.
Actually, I'll bet he's improving the recipe/combo a bit by running the big tube ARH headers and the chrome moly flywheel - which would help the dyno results.
well I'm not really sure what to say to those that dont believe me. feel free to get in touch with the shop that did the dyno
http://www.dyno-shop.com/
Hal was the tuner and i was obviously pleased with his work... the car pulls hard and had no drivability issues. what more can you ask for. I would be happy to have it dynoed on a different dyno if someone else is paying the bill i plan on using the same shop after the intake and exhaust so i can see what the actual difference before and after is.
yeah i plan on getting some track times the next time they have a test and tune day at the drag strip in syracuse.. i will be on street tires tho
if the 60' times are really bad then i may look into some et streets
1 Post
I am most happy to hear that your tuner sent you away with zero drivability issues. Gotta love all that extra power with a stock driving experience.
BTW what were you baseline numbers ? I am assuming the car was baselined before the swaps and tune were done.
