Formato Tuned and Texas Speed H/C C6 Z06 586 NA rwhp
Old 08-03-2009, 04:14 PM
LS1TECH Sponsor
JeremyF's Avatar
Default Formato Tuned and Texas Speed H/C C6 Z06 586 NA rwhp
Hey all, just wanted to show a great example of a 07 C6 Z06 with Texas Speeds / PRC heads (milled .050) and cam package and our tuning. This car has much better than expected drive ability, and makes nasty NA power through out the rev band with a stock bottom end. The cam is a 242/252 650/650 114 +3, the car has a Vararam CAI, factory modded exhaust, our ported intake and throttle body and tuning.
Talk about bang for the buck:
Old 08-03-2009, 06:40 PM
venom ws7's Avatar
Holy awesomeness GREAT Work on the tune A/F Ratio look really freakin street.
Any plans for the FAST 102mm Intake and TB??
Is that TSP LS7S cam??
THANKS FOR SHARING.
Old 08-03-2009, 06:51 PM
Black02SS's Avatar
I'm guessing compression is in the 11.9-12.1 range? What is the "modified" factory exhaust?
Old 08-03-2009, 07:12 PM
OUTLAWZ RACING's Avatar
Sweet.
Old 08-04-2009, 04:39 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Compression on that motor is at 11.6:1 with them milled that much. That is our LS7S cam.
Old 08-04-2009, 04:56 PM
Black02SS's Avatar
Which head gasket was used and what are the stock valve relief's at?
Old 08-04-2009, 04:58 PM
LS1RedZ's Avatar
DAYUM! Thats some nasty power all motor!!!!
Old 08-04-2009, 05:46 PM
It should be with a stock LS7 head gasket and the stock -3cc valve reliefs in the piston.
Old 08-04-2009, 06:07 PM
Shorty Director
VINCE's Avatar
Sweet setup!! Congrats!!
Old 08-04-2009, 06:52 PM
THENASCAR's Avatar
DAYUM! sweeeeeet. now for some headers and a catback and that oughta go over 600 whp. great work!
Old 08-04-2009, 08:26 PM
Black02SS's Avatar
I guess I don't understand how the compression is so low. From my math you took almost 8.5cc off the heads (.050). That brings them to about ~62cc. Based on what you say with the heads, stock pistons being -3cc, and a stock gasket (compressed .053), I come up with about 12.2 compression. This is factoring in a piston out of hole average of .008.
Please educate me on the math please.
Thanks
Old 08-04-2009, 08:59 PM
sandragnx's Avatar
I thought valve reliefs on stock ls7 pistons were -7cc.They have 4 valve pockets for some reason.
Old 08-04-2009, 10:07 PM
Dutchman427's Avatar
Very nice.
Old 08-04-2009, 10:10 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Chad, I think the LS7 pistons do not come out of the hole such as the other LS motors do. Don't quote me on that, but I will check the next stock one I tear into just to verify. As far as compression math, you could always coax the cc numbers in compression calculators to duplicate the stock compression ratio of 11-1 and then make your changes in milling, gasket thickness, etc to find the new compression ratio. This is useful if you do not have the known compression height, or chamber volume.
Old 08-05-2009, 05:46 AM
Black02SS's Avatar
Thanks for the reply. I did as you said and used the following values as a baseline. Figure stock compression of a LS7 is ~11:0
Bore 4.125
Stroke 4
Rod Length 6.067
Deck Height 0.008
Piston Relief 3cc
Compressed Head gasket thickness 0.06
Cylinder Head Chamber Volume 70cc
Static Compression ratio = 10.97
If you change the volume to 62cc and that being your only change, the compression factors out to about ~11:9.
I am not trying to take credit away at all from the results as they are awsome. I am trying to figure out the correct compression on this motor.
Thanks!
Old 08-05-2009, 08:04 AM
registered user
ScreaminRedZ's Avatar
Vasy sick power! That car will make alot of turbo cars unhappy, lol.
Old 08-05-2009, 10:17 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Chambers were closer to 64.5-65cc. And that piston isn't out of the hole on all cars...Jason and Trevor's Z06 cars both had them in the hole a few thou!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 08-05-2009, 10:21 AM
Restricted User
98Z28CobraKiller's Avatar
I would love to see some track numbers to backup these dyno numbers.
Old 08-05-2009, 10:55 AM
registered user
^I'm guessing they'll see 135 traps like that other C6 Z that was making 580 rwhp. Freakin crazy numbers!
Old 08-05-2009, 04:32 PM
LS1TECH Sponsor
JeremyF's Avatar
The NPP exh was cut open rewelded perforated pipe removed and sound deadening stuff removed, REALLY LOUD, might improve the flow a small margin.
We may do a LSX 102 on there, at least the testing. The manifold we did for it picked up 14rwp and 17rwtq, one of the lower ones we have done but the tune was really aggressive and many time you need to retard timing with a denser air charge.
Stk head gaskets, the car does have headers on it but with the modified stk mufflers.
This car ran 6.8 @ 100mph 1/8th mi before the 100 hp gain from the heads and cam.
will be back at the track in the next few weeks. 135mph+ should be feasible.
Jeremy Formato
Quick Reply: Formato Tuned and Texas Speed H/C C6 Z06 586 NA rwhp
