Gained 20RWHP/58TQRW with only powerbond underdrive pulley !!
Hi , like it says , i'm not trying to lie or anything but this what happened and i'm very pleased with the results , same jets with previous tune and timing did't changed anything only i installed POWERBOND underdrive pulley and NGK BR7EFS plugs instead of TR6 , the car pulled 596RWHP 584TQ and car still rich i should change the fuel jets and i believe it will hit +600RWHP , timing set 20 degree.
this is the old dyno run with TR6 and without pulleyhttps://ls1tech.com/forums/dynamomet...ms4-chime.html
i'll try today to post the graph as soon i get the graph from the tuner
Updated Post #29
Updated Post #29
allah ybarek feek , today i'll post the graph and here you're the video
http://www.youtube.com/watch?v=47jRLcKcAwA
sine the spark plugs were alsochanged I think maybe a spark plug had a bent tip or damaged or a spark wire not connected properly .... seen it before ... this is the explanation I can come with for the +50 tq gain.
You did not gain that much power from a underdrive pulley. The bottle PSI was higher, the A/F was leaner, you were detonating before with the TR6's, something to that nature. A underdrive pulley does not give nearly that much power..lol.
also, did you remember to put the belt back on too? lol, seems to be pretty high for such a slight mod. i would have to say something was messed up on your dyno numbers before the swap, either way, you have it fixed now!
the car runs very perfect with TR6 and i raced many fast cars and no problems on there .
