Anyone have dyno Comparson: SC vs Turbo
Anyone change from supercharged to turbo charged and have before and after dyno graphs to share (prefer same boost level, but ok if they are a bit different)?... Thanks in advance.
might wanna give your mod list to get better results. what kind of power range you looking for, what cubic inch are you, mods, fuel system, meth or no, etc...
also, i doubt many people will have their setup on a s/c and then the same setup for a turbo (or twins) so dont expect those. the forced induction section and a search would prbably be your best friends...
I remember there being a chart around a few years ago which demontrated the differences quite well. I have searched high and low with no luck.
LS1Tech Sponsor
346, Thunder Trak Cam, AFR 205s, Fast 90/LS2 90
First set up is with a P1-SC @ 7 psi.
2nd set up is same but with twin 67s instead of the P1SC, and at 11.5 psi.
Just a little difference, lol.
Next set up will go 200+ in the mile....
__________________
Check out the Trinity! Visit our support forums
Follow us on twitter! Check us out on Facebook!
Check out our NEW website!
I need to better comunicate what I'm looking for: representation of boost/power curves. I am not necessarily looking to show which one makes more power or which one is more efficient...just how the power curves come on.
LS1Tech Sponsor
Considering it was same short block, same H/C/I set up, just different means of providing boost, I thought it was a pretty good comparison.
If anyone is interested, I have dynos for that combo N/A, as well as with a 100 shot. Pretty interesting stuff.
Well, maybe if the OP is lucky, this thread will fill up with people complaining about apples to oranges, instead of providing some useful info....
I answered the guy saying "That is a big difference" hence my response. (post above mine)
Useful info is 2 power adders (how much more air were the twin huffers pushing Vs the CS?, I bet quite a bit ), and 4.5psi difference you should be able to (theoreticaly) hit another 25% (on a well thought out FI combo) in power increase.
The only thing those graphs show you is that CSCs are linear with rpm, and that Turbos (especialy TT) will shift your trq down low in rpms, giving you a totaly different curve. (Anyone having dealt with FI should know that).
My reponse was toward the power difference not towards analysing power curves
(someone patient enough would recognise that instead of bashing, don't you think?)
don`t know wich or where the magazine is .... but maybe it was HOT ROD magazine they did a comparison on the same engine on the same dyno with a roots , cinterfugal and a turbo at the same boost
lower rpm mid rpm high rpm
roots Best falling Worst
centerfugal 2nd Best 2nd
turbo Not Working Rising Best
don`t remember the turbo numbers just remember it was the best at the end and at the important to me higher rpms
Turbo for the win at the streets no rotating robbing power
I don`t feel like looking at all the magazines I have ....
It was a Muscle Mustang and Fast Ford Article (dont know the year), but it did a great job of illustrating what I'm looking to demontrate. Thanks to all that tried to help with my request.
it wasn`t this article it was on eof these three Hot Rod , Popular Hot Rodding or Chevy high performance {---not sure of the name
but that`s some reading to do later on ^_^ thanks for the link
I agree with you but what i do not like about them here is the amount of heat they generate. I found that Centrifugal is the friendliest (and can make equal power in a properly setup combo)
CFS are much much more reliable in our environment (sand, dust and heat)
Not to mention they can be taken off a lot quicker for the Popo inspection upon registration renewal
LOL! loved also the running with one nose hole open comment about the one who asked to do a stroker with stock heads although I prefer a cammed stroker stock heads over a good heads cam car
if the car is inspected eaither try to redister it without taking it or have someone from there to pass it .... or replace with a rented stock engine from the junkyard just for that and later back hehehe
if money isn`t a problem then turbo .... money and hassle wise the near highest boost you can do on the fuel octane you can afford regularly centrifugal supercharger
Last year they made me put back my original muffler on (although I've been running 7 years without one), but the idiot failed to say anything about the cutout or the nitrous plate
you should have seen his face when he was looking for the battery
You have to physicaly go and register here.
I've seen one guy fail because he changed his exhaust tips.
They just do not have any clue.
hahaha on the battery .... baucause of tips? @@ jaw drop
here you have to go physically also but if you know someone that knows someone well you know ..... NEW REGISTRATION DELIVERED TO HOME FTW !
