Retune ?????
Retune ?????
I have a 2001 Formula LS1 with the following mods.... Slp cold air pkg, ZO6 intake, heads (243's) and cam (204/218 X .550/.550) at 117 lsa, Pacesetter longtube headers, Loudmouth catback 3" exhaust, stock 4l60e trans with stock converter, 373's with Eaton posi, 275x60x15 DR's and skinnies. Had tune done last week. RESULTS....... 334.85 hp. 342.21 tq. after 4 pulls. Do I have a problem or are these #'s Good Thanks.
what do you mean by z06 intake? You mean the MAF?
Also that is a very tiny cam. Although your heads alone should bring you those numbers by themselves. I would guess that you should be around 350rwhp.
A nice torque converter will cheer you up.
well i am curious why you listed that as a mod seeing as though you 2001 came stock with a LS6 intake manifold. I hope noone ripped you off telling you that it was a "zo6 intake"
what kind of dyno was it on? its not that far off from whta a stock C5Z would be dynoing, considering its absically the same setup. figure 8-10% for most mustang dynos would be right around ~370ish so id say its not that bad, IF ITS ON A MUSTANG DYNO THAT IS. [very] small cam, unported heads through an auto would pretty much be right around that in my book.
thats what i noticed as well...
Well I appreciate everyones input. I guess as the saying goes..... "It is what it is" applies here. I'm taking it to the track tomorrow (1/8mi.) and get some #'s on it. I'll put the results on the LS1 Tech Drag Racing Thread. Thanks again.
well ill definitely look for that thread. dont worry about youre ET, alot can effect that. just lsearch around here on threads for cars with close to your setup, or your power levels, and compare that trap speed with yours. that should be the telling factor.
so did you really buy this "z06" intake even when you have an ls6 already? or was yours damaged in some way?
I ran the car before the tune a few weeks ago. Best 1/8mi. run out of 7 was 8.37 @ 87.6mph. 60ft. 2.01. All runs were close to these #'s. Tomorrow I will see what the tune has done.
no need to apologize we`ve all been there and we still make mistakes and localy we call it a ZO6 intake to lol
you stated 243 heads so you know they are suppose to have that number on the heads
when you look at the heads can you see those numbers? 241 will be the stock 2001-2002
is the LT headers connected to the stock Y pipe like mine came with when I bought it? fixing that alone changed my car.
not saying your numbers are good or bad
Heads are clearly marked 243's. Was there ever a cam change ????? Seller told me motor had ZO6 cam, but that does'nt matter cause everyone on LS1 threads say the cam is small anyway ! Don't know what the timing was set at or if AFR is within those specs. The tuner never gave any info on the dyno results and when I started to ask a question his answer was " If there was something wrong I would've told you" ! End of story. So here I am today totally confused about who, what, where, when........ Once again I really appreciate all the feedback cause it lets me know that the car has some issues that I have to resolve.
maybe they wont charge much to hook up a wideband and just dyno it. They may be able to tell you if the tune is bad without actually retunning it.
Im just saying to give it a try before you dump alot of money into the engine just to later find out that your engine was fine to begin with.
No matter what happens Good Luck buddy
