418ci high compression budget result cut-out o[en and close
a used shortblock:
6.0 iron , 4.100 eagle crank , 6.125 H scat , wiseco 4.030 +5 dome , ls6 oil pump , JW adjustable double roller timimg chain , stock spark plugs
11.76:1 calculated SCR by me 11.72:1 calculated by another
top end:
prc 317 stg 2.5 72cc 2.02 1.57 675 lift EHT springs
239 int 247 ext 625 625 114+2 LSL lobes installed dot to dot
ls7 lifters
stock valve seals (previous was passing oil)
HarlandSharp trunion new stock rockers
7.450 pushrods
cometic .060 head gaskets
msd 8.5 wires
induction:
ls6 intake , ported stock tb ,tb bypass , egr delete , air delete , FTP plastic maf ends , clear lid , holley powershot filter , slp cai cut to above the radiator
asp udp
fuel:BBK pump + pump booster kit
42 lb/h racetronix
exhaust: (police and tickets restricted)
1 3/4 LT headers leaking for the driver side flange or one or more of the ports(needs repairing or changing , will do later with what I`ll find and willing to pay budget wise)
3"ORY , stock catback with DMH 3" cut-out before the muffler
drivetrain:
T-56 swap
ls7 clutch
stock aluminum driveshaft swap
stock rear with a stock whining 3.42
245/45/17 taiwan wheels (aluminum or something)
I remember a cool 102 F temp at the night and I was told the timing was 26
93 oct pump fuel
no info on the baro or humidity , no data on intake or injector duty cycle
wanted atleast 450 rwhp cut-out closed 470 rwhp cut-out open sae to keep the cam and keep modding future plans is to swap the cam for a stealthy stock idling one and better driving surge wise (1200-1700 rpm)
ported 92 fast with a 92 or 96 tb , another headers later
and thinking exhaust set up (C6 or C5 mufflers cutting the trunk or fuel tank price searching localy or leaving it stock but with 3" to muffler and better 2.5 or 2.75 after muffler)
SAE:
STD:
WOt was from about 2800 rpm to 6600-6800 rpm (forgot to tell him to change the speed to rpm)
top end:
ls7 lifters
7.450 pushrods
msd 8.5 wires
induction:
asp udp
42 lb/h racetronix
drivetrain:
T-56 swap
ls7 clutch
93 oct pump fuel
SAE:
STD:
LS1 Tech Administrator
That is a pretty mild cam for a 418. Any bucking and surging can totally be eliminated with a better tune. The equivalent cam in an LS1 would be around a 228/236 114LSA so you don't have a monster cam by any means.
A ported FAST with a 92-96mm TB would add around 25-30rwhp and 1 7/8" headers would add at least 10rwhp, maybe even 20. So basically, with a better tune and the mods you plan on getting, you would easily meet your power goals. My advise, find a better tuner if they can't tame that baby cam. Also, your catback could probably use some work if it's hurting you 35rwhp when closed.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
hmmm it will be fun ... better than everything once and then nothing to do ^_^
I wanted these goals with the ls6 intake lol
but oh well .... I want a stealth idle now since I didn`t make what I wanted ... ..... now I`ll wait a month or two then add stuff
hmmm but there is no screen or the center section of the stock maf it`s almost straight through now with the plastic ends
oh and this is the third tuner I try ^_^ first tuner on my old cam only 224 224 114 was surging
the second couldn`t tune the car (didn`t find the problem wich was the fuel pump)
the third tuner is very good and supposedly street drove it and tuned it (that was the deal but I wasn`t there)
