C5 dyno opinions needed
ok Im a newb, but Not to the scene. I have a 04 c5 with only mods being a k&n Intake, and a tune. Its an auto. Stock exhuast, no intake or exhaust leaks.
I had it dynoed a while back and here is the slip 295whp/302wtq
Now the shop said it was running lean. We moved the sensor to different tips on different runs, but got the same reading. The a/f stays at about 14.0-1 most of the time at wot. And there is a nice pot hole in the pull at 5200 rpms.
What do you guys make of this? Is it really lean? or is the dyno sensor reading false? Supposed to be like 26-27* of timing, but no KR. Shop said If I threw some fuel at it I could see another 15whp or so... This true?
When it's that lean it's hard to say if you'd pick up anything. Alot of the gains are made from leaning the usually rich WOT condition from the factory.
Depending on the knock retard, you may or may not have any significant gains. BUT, tuning an auto makes all the difference in the world. They usually have a much more dramatic SOTP feeling than the M6s do.
The big dip is probably knock retard. That would be my guess anyway.
Not that anyone cares. But I fixed the problem. here is the before dyno
Here is the after dyno.---
Picked up 13whp and 17.1wtq no knock, better a/f and much better low end and way way better top end. What did I do you ask?
I had to take it to the dealer and reflash the ecm to stock. Because the guy that "tuned" it would not return calls, texts for over 2 weeks. Cost me some $$$ because the dealer likes people to grab their ankles. Would have been free if the guy would have just loaded the stock tune back on. Hope the motor didnt get hurt.
Scary results from a "friends tune". It is really sad how everyone fancies themselves a tuner because they own a laptop and can change oil.
Good to see you got it fixed.
I mean I can understand missing a call, but its like he was avoiding me. Funny thing was I could hear knock, and caught lean codes... And they/he dismissed the a/f on the dyno to be a false reading. And didnt want to tune again without a wideband. I knew something was wrong. But they wouldn't listen.
Thank you. took about an hour. cost $99 but I had to drive to 3 dealers because first 2 were too busy. Then $60 for another dyno. Other dealers charged $157 and $128... the one that could fit me in, was also the cheapest.
I am. Funny thing is I usually have a pro do it. But this was a "discount" tune. I just payed for credits... $100, Dyno $60, dealer re flash $100 redyno $60 back to stock. about $320 plus hassle and gas driving all over the earth to have a stock tune made worse, then back to stock again. Last I checked The pro did tunes for $300 so yeah, would have been cheaper to get it done right the first time.
or you could have had a guy (who actually knows what he's doing) like me do it for 200. I can't believe he even used a dyno and still jacked the car up. Your car is basically stock.
Just wondering, what gear do you have? I had the 2.73 with a tune, volant intake, and some quiet catback and ran a best of 12.76@110.
I believe its a 2.73 gear and stock 4l60e. Stock I ran a 13.5 @105 with a 2.1 60ft. I am sure I can get the 60ft down with a little practice. I was hoping for a good 3-4mph gain with a "real" tune.
So your saying that the tune was good, I just needed to clean my maf, and get a pre cat a/f??? splain the lean codes, and KR for me then.
If you have a 2.73 it will shift out of 2nd at about 100mph. I ran a 2.0X best for my 60ft. No tire spin at all, no brake torquing, no burnout needed. It was opening day too so the track may have been prepped well.
FYI the dyno uses a vacuum type a/f meter. From what I have heard it is about as accurate as a wide band. Also wanted to point out that the main reason, other than KR, that I had the ECM re flashed was because I failed emissions twice. Both from all of the systems being in not ready mode. I was going to put it off but I got pulled over. I tried driving it allot thinking that would fix the emissions system being we don't drive it a lot. But it didn't. The re flash fixed everything.
