Yella Terra 1.85 rocker on L92/LS3 heads dyno results
The Gen IV rectangular port GM heads really respond to lift. This has been proven time and time again. But instead of a cam swap, I wanted to see how much power I would pick up just by swapping some higher ratio rocker arms to increase the lift at the valve.
The test engine was a 2009.5 G8 GT with a 6.0L L76 engine with active fuel management (DOD). All AFM motors are saddled with a very small 200/208 .472/.474" 116LSA camshaft. The 1.85 rockers would effectively increase the lift at the valve from .472 to .514". This small but noticeable increase in lift will get the large intake valve further away from the cylinder wall plus into a position where it flows more air. Effectively my engine now has a 200/208 .514/.516" cam.
For those who can't read the dyno chart, peak power increased from 342rwhp to 355rwhp (a gain of 13rwhp) and torque peak increased from 355rwtq to 362rwtq. Interestingly, both the power and torque peaks with the high ratio rockers occurred at lower rpm, but carried the power better at higher rpm. This helps pump up the overall power under the curve.
While this is a very easy mod to install, it does require a couple of other items. The heavy solid stemmed intake valves of the L92 heads did not like running the high ratio rockers with a stock valve spring. We ran into valve control issues at 5400 rpm with the stock springs. We swapped some Comp 26918 beehive springs and the curve was beautiful. The Yella Terra rockers also require a longer 7.450" pushrod to keep the valvetrain as quiet as stock.
So if you're looking to gain 13rwhp without swapping cams, the Yella Terra 1.85 ratio rockers are an excellent way to boost the power of your L92/L76/L99/LS3 engine without opening up the motor.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
LSX Mechanic
Good info Patrick.
I just put a "New Era/FTI" D.O.D. cam in a G8 a little while back, but deleted the D.O.D. anyway so there's no restriction on lift with those lifters. Maybe I'll suggest these rockers and see what we can squeeze out of it. The DOD cam is only .575 lift.
LS1Tech Premium Sponsor
Interesting results Patrick, I didn't see anywhere near that kind of gains with 1.85 rockers on the engine dyno.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I like the writeup patrick. Can you say how much the rockers are and the part number?
I was thinking about something like this for my 09 G8 GXP. I wanted to keep stock manners 100% and not lose one ounce of driveability and no real noticeable noise increase. I have heard that the Livernois Stage 1C cam gets close to stock driveability with it's 219/228 .60X/.59X 118.5lsa. I just don't want to sacrifice anything with this car.
I am hoping the rockers make a strong improvement. I was hoping to see more power from idle to 4000rpms, but like you stated it is good to see it pulling strong to redline.
Any cam suggestions would be great if you think the dollar/hp isn't worth it for those on the fence about a cam.
Were you starting with a low lift .472" L76 cam or a .550" LS3 cam? If you started with a low lift cam and didn't gain much, that would surprise me more than if you started with a high lift cam and didn't gain much. There will be a point of diminishing returns at some point.
__________________
The YT rockers are not heavier over the nose than stock. It's asking the heavy valves to accelerate faster than what the stock springs can handle that leads you premature valve float.
__________________
Interesting results, same day back to back?
Yes, by a very small amount.
Wouldn't the rockers also change the duration since you are effectively make the lobe bigger from .006 all the way to max lift?
Nice results. Im suprised no naysayers, since everybody use to say the slp 1.85 rockers was a waste on the stock ls1 for the cost. "Might as well go with a cam swap".
However I have been extremely satisfied with the 1.85's on my car, especially since they cost me nothing!!
1. The LS1 is smaller than the 6.0L
2. The L92/LS3 heads gain more flow going from .450" to .500" lift compared to the LS1.
3. The L76 runs and even smaller cam than the LS1. Any help you give it will show some nice gains.
__________________
Hello patrick, I'd hate to bring this up from the dead a little bit but I have a question for you. I have been asking around and no BIG players in the game have made up their minds about these L99 motors (for my 2010 camaro) and how to cam them. Some say I have to delete the DOD and VVT in order to do it, while others say SURE here is my stage one just get the cam phaser (set to stun) and slap it on and tune it!
But anyways Ive decided to wait until I see what is really working and what isint.
I want to do the YT RR swap and I would like to kmow if I would need different springs?
And would I need new Pr's if so what size would I need?
I would also like to know where you got the 1.85's because I have looked and most only carry 1.8's.
thanks
thanks
Most of your questions were answered in post number one (underneath the dyno sheet). Yes, you'll want to replace the stock springs with a quality beehive like a PAC 1518 or Comp 26918. You'll need to run a longer pushrod to keep the pre-load within factory specs (otherwise you'll get lots of clatter).
VVT cams in an L99 are outstanding with these rockers as you'll be able to run a cam that is compliant with both VVT and AFM/DOD while getting your lift into the mid .500s. The best part is, you can do all this in phases. Do the rockers, springs, and pushrods now, then add the cam, cam phaser limiter kit, and tuning later as your budget allows.
__________________
1.85 rockers on an LS1 will not give as much of gains for several reasons.
Really? Thats weird because I have seen dyno sheets showing gains of 10whp and 17wtq by swapping to the 1.85's on the ls1... There was a thread last summer in here of a guy posting these same results?? Either way I did not pay for them, they were on the car with upgraded springs when I bought it.
No. It's a weird cam.
__________________
