Baby EPS cam lays down 430rwhp/415rwtq with track results!
Old 01-10-2010, 10:53 AM
  #41
skorpion317's Avatar
I'd really like to hear some sound clips. I'm looking for a sleeper cam, and this just might be it.
Old 01-10-2010, 12:39 PM
  #42
"All Motor 9 Second club member"
TXCAMSS's Avatar
Ok guys, here's the idle clip. It's still hard to get a good feel for the sound on a video, but it'll give a decent feel for the lope you may be looking for. The cold start idle is like 950 and as you can hear it drops down to 775rpm as it warms up. I have a full 3" y-pipe exhaust on the car with a Magnaflow Y-merge collector and custom Y-pipe 98Aggie fabbed up for us. The muffler is a Dynomax Ultraflow welded. I think an SLP Dual/Dual would be quieter, but my wife likes it the way it is and since it's her car, that's how it'll stay I guess.lol
Old 01-11-2010, 05:22 PM
  #43
aTeam's Avatar
You said this is on an ls6 right? Would this cam bring an ls1 with full bolt ons, patriot heads and fast intake + tb into the low 11's too? That's an awesome combo, good job.
Old 01-11-2010, 05:44 PM
  #44
TXCAMSS's Avatar
The Patriot heads probably flow better than the stock 243s so there is no reason you couldn't hit low 11s with full bolt ons.
Personally we are shooting for 10s NA with better air and a better prepped track surface
Old 01-11-2010, 06:48 PM
  #45
aTeam's Avatar
I think I could hit 10's at Englishtown with that combo.
Old 01-12-2010, 04:23 PM
  #46
[video]
That's awesome! That's exactly what I'm looking for. From the video, it sounds pretty close to stock.
Old 01-12-2010, 07:19 PM
  #47
TXCAMSS's Avatar
Yeah with the cut-out open there is a slight lope, but idling it up to 950 rpm when warm would fool the majority of the victims
Old 01-17-2010, 10:19 PM
  #48
TXCAMSS's Avatar
Yeah it was right at -550 to -650 during the 3 passes we made before we got rained out and kicked out That's pretty decent air, but we see sub -1000 DA in -March sometimes.
Old 01-18-2010, 10:01 AM
  #49
airforcemanss's Avatar
so it took the wife 3 days to realize it had an extra 75-100 rwhp? lol
Old 01-18-2010, 01:30 PM
  #50
TXCAMSS's Avatar
Yeah it was cold and wet most all week, but she did notice the extra power, just putting around town. We also swapped in a tighter stall converter at the same time so the car feels totally different than before.
Even with dry streets traction is non-existent with any kind of aggressive driving.
Old 01-18-2010, 04:26 PM
  #51
Sofls1's Avatar
I see the converter is a circle d probably a multi-disk. How is that around town? I am running a Vig on my DD with the same setup and it leaves something to be desired in the driveability area. I am thinking of switching to a circle d
Old 01-19-2010, 11:38 AM
  #52
TXCAMSS's Avatar
I actually did not go with the multi-disc on this Cirle D 3B converter/set up since I didn't plan to lock it up at WOT other than for a few dyno pulls. It actually feels very nice around town. It takes very little pedal to get the car moving good and it couples quick. It's driving manners are exactly what we wanted with this set up. It makes the car feel lighter than it is, if that makes any sense.
Old 01-19-2010, 05:12 PM
  #53
Sofls1's Avatar
So that's not the disk type? I understand what your saying about the drivability part. I'm looking to try something different.
Old 01-20-2010, 06:24 PM
  #54
TXCAMSS's Avatar
The lock up disc is normally just used for freeway/cruise speeds when you want the best fuel economy, but it is common for motorhead enthusiasts to manually lock up the converter on the dyno for more accurate numbers and better tuning capabilities. Some also lock up the converter at WOT for a little extra et/mph, but this is usually only beneficial on power adder cars as it bogs the car down significantly. The multi-disc is recommended for this service as the standard single disc lock-up clutch isn't designed the handle that kind of stress. Circle D has a very strong and proven lock up clutch that can handle quite a few dyno pulls so I wasn't too worried
The rest of the converters internals and the way they are set up determine stall rpm, loose/tight and the TCs efficiency.
I hope that helps!
Old 01-20-2010, 07:14 PM
  #55
1969mach1's Avatar
What tires and size were you useing at the track?
Old 01-20-2010, 07:30 PM
  #56
quews6lime's Avatar
wow....is all that running on a stock tranny...r a built one?
Old 01-20-2010, 08:14 PM
  #57
PowerShift408's Avatar
Not trying to take anything away from the OP because the car obviously runs great and makes great power, but it is not a cam only car, it has 243s.
Old 01-20-2010, 08:38 PM
  #58
NateLS1's Avatar
243's came stock on an LS6.
Old 01-20-2010, 08:55 PM
  #59
TXCAMSS's Avatar
Yes and no. It was a bone stock LS6 long block from SDPC. No, it did not come in this car from the factory, but the heads never came off the engine to be modified. Ultimately, it shows the potential of adding the very affordable bone stock 243s and adding a custom cam to match the cars set up to get the most out of it.
It shows you don't have to spend big $$$ to make well over 400 rwhp and don't have to deal with uncomfortable driving manners from a big cam and half a$$ tune.
That's just my .02
Old 01-20-2010, 09:13 PM
  #60
eddielb's Avatar
thats some crazy power and something im very interested in doing now ~ but my car has a ls1 with 135k miles so im sure im going to have to do other upgrades while im at it to make sure **** don't blow up. haha so talk to patrick about details eh?
Quick Reply: Baby EPS cam lays down 430rwhp/415rwtq with track results!
