guys with super victor intake step in
Restricted User
If you are looking for a higher peak power number on the dyno, then it will probably work nicely for you. If your goal is to go faster down the track, it will not work for you. Power under the curve will suffer badly. The FAST will out perform it to 6400-6500 RPM badly. After that the Super Vic will start to pull away slightly but not enough to make the car go faster with a 7400 RPM redline.
