6.0, LS3 Topend, EPS (Pat G) 226/234.
Old 06-07-2015, 03:12 PM
MASS seller approved
low2001gmc's Avatar
Originally Posted by IRONFIST
I'm running a very similar EPS cam in an LQ9 with LS2 heads, making me wish I had gone LS3 top end.
If your cam is on a at least 112 lsa, you could use it and swap to ls3 heads. If you wanna discuss, just pm me...Rob
Old 12-14-2016, 08:08 AM
Ozz1967's Avatar
I just found this thread so I'm "only" bumping a year old thread. Not as bad as the last guy who bumped it from 4 years ago! Anywa...I'm building a 6.0 (LQ9) but I'm going to be using this cam from EPS to go with an LS6 intake, stock 317 heads. Exhaust is to be determined...either factory LS3 logs or some BRP mid-length headers...1 3/4 primaries. May run dual or single 3". Haven't gotten that far in the process yet. Goal is 400whp, 400tq. Not sure if I can get there with those stock heads though. Going to be in front of an auto. 3.73 gears in my 84 T/A.
Old 12-17-2016, 03:12 AM
BODUKE's Avatar
I have the exact cam from EPS it kicks ***.
Old 12-17-2016, 11:36 PM
KW Baraka's Avatar
Originally Posted by Ozz1967
.....I'm building a 6.0 (LQ9) but I'm going to be using this cam from EPS to go with an LS6 intake, stock 317 heads. Exhaust is to be determined...either factory LS3 logs or some BRP mid-length headers...1 3/4 primaries.......Goal is 400whp, 400tq. Not sure if I can get there with those stock heads though.......
400HP to the wheels? Yeah, you can do that with the stock heads.
400TQ to the wheels? Yep.....you can make that, too,
BRP mid-length headers? I have mid-length on my Impala and they're holding me back to the tune of about 30 to 40 HP. I'll be switching to some 1 7/8" long-tubes and would recommend you go that route as well.
KW
Old 12-18-2016, 09:48 AM
Ozz1967's Avatar
KW
That's great news to hear! Unfortunately with an auto trans in a third gen, it's next to impossible to get dual exhaust past the transmission.
Old 02-06-2017, 06:21 AM
jmilz28's Avatar
https://www.kooksheaders.com/automot...-engine-413221
Old 02-06-2017, 02:44 PM
Ozz1967's Avatar
I don't see any for a third gen Camaro/Firebird unless um looking in the wrong place.
Old 02-07-2017, 11:34 AM
KW Baraka's Avatar
What's the biggest single exhaust available?
Maybe go to a muffler shop and have them fab you a 3" or 3.5" single exhaust?
KW
Old 02-07-2017, 12:06 PM
Ozz1967's Avatar
KW
I'm looking at a couple of options. Knowing I can't easily go past the auto trans is one reason I dropped $500 for the Mast ls swap oil pan. It's only 1/2 inch deeper than the factory Fbody pan in the sump but it's also 3" shorter in the sump (8 inches vs 11 inches) from front to back. I'm curious to see if it will give me enough room in front of the pan to run a factory style 2.5" y-pipe around the front.
If it does, I will be able to run my current 3" catback with LS3 style of 01-02 Factory iron manifolds.
If it does not, I will probably look locally to see if I can have a cross member made with the "bat wings" so I can run dual exhaust.
Old 02-07-2017, 01:43 PM
Ozz1967's Avatar
KW
I do have to say, I would love to have one of those SS Impala's that you have...especially the 96. Both are awesome cars though.
Old 02-08-2017, 02:52 PM
KW Baraka's Avatar
Thanks!
BTW.....the '96 will have a 24x conversion by the end of the week. I had been revving it to 6600 RPMs. With the 24x and the GEN-4 ECU, I should be able to rev clean to 7300 (or so) RPMs.....AND gain 10 to 15 HP/TQ through the entire power curve.
Can't wait to get her back!
KW
Quick Reply: 6.0, LS3 Topend, EPS (Pat G) 226/234.
