383 s88 turbo dyno
Old 07-17-2011, 05:56 PM
ls1curt's Avatar
Default 383 s88 turbo dyno
got the car tuned yesterday.
383 ls1-eagle crank/rods/aries pistons ~10.4:1 comp.
317's w/ patriot dual golds
comp 236/232 .598/.601 115 lsa
fast 92/90
truck manifold turbo kit built by me
forced inductions s88 turbo 1.32ar, turbosmart 48mm wastegate
dual walbros/8an feed/80lb injectors
th400/12 bolt
car ended up making 714whp/568wtq @ 15psi on 93+meth
Big thanks to Don (Slowhawk) for the killer tune and for clearing up some problems i had.
the car is an animal on the street will hopefully be going up to the track in about 2 weeks
http://www.youtube.com/watch?v=ZDBvvcNZeIw
Old 07-17-2011, 07:44 PM
LS1Tech Sponsor
Slowhawk's Avatar
Car is awesome. Post up the other graph that compare's the nitrous to turbo.Definitely a big gain.
Old 07-17-2011, 08:26 PM
ls1curt's Avatar
thanks Don. been doing a ton of driving/pulls
Heres the graph of turbo vs. nitrous. fyi the car went 6.4@108.8 with the nitrous
Old 07-17-2011, 11:30 PM
Detoxx03's Avatar
Impressive results. Whats up with the torque though? I would expect it to make more.
Old 07-18-2011, 12:06 AM
obZidian's Avatar
Nasty!! What stall? Car should be literally a freak when it gets into boost. More vids please!!
Old 07-18-2011, 05:41 AM
ls1curt's Avatar
stalled auto w/ 3.73 gears are not dyno queens
Old 07-18-2011, 05:42 AM
ls1curt's Avatar
thanks, its a yank 3900 custom spec'd for my setup
Old 07-18-2011, 07:34 AM
98transguy's Avatar
my torque was a bit higher with my somewhat similar setup as seen in my graph below, very nice numbers, any chance in putting in some c16 and cranking the boost to about 20?
Old 07-18-2011, 12:31 PM
Detoxx03's Avatar
I'm aware of that cause I own one. I would expect at least 600 thought but in the end i'm sure its a beast. Congrats
Old 07-18-2011, 02:40 PM
LS1Tech Sponsor
Slowhawk's Avatar
The torque is low due to the gear and converter slip.
Old 07-18-2011, 03:40 PM
bjschubert's Avatar
What exhaust are you running it sounds Nasty! I love it!
Old 07-18-2011, 04:04 PM
obZidian's Avatar
Was the converter locked during that run?
Old 07-18-2011, 04:06 PM
ls1curt's Avatar
4 inch with a dynomax bullet dumping before the axle. th400's dont have lockup...
Old 07-19-2011, 08:45 AM
obZidian's Avatar
Nice!
Quick Reply: 383 s88 turbo dyno
