Vengeance Racing Builds Synergy Green 2011 Camaro. Whipple/Cam/Fuel/Rear/Susp/Meth
Old 10-07-2011, 04:51 PM
Kevin@Vengeance's Avatar
Default Vengeance Racing Builds Synergy Green 2011 Camaro. Whipple/Cam/Fuel/Rear/Susp/Meth
Vengeance Racing Builds HufferSS’s
2011 Superchaged Synergy Green Camaro SS
This Build Consists of the Following Modifications:
· Whipple 2.9L Supercharger
· 3.5” Pulley with Carbon Jack shaft cover and inlet tube
· LPE Twin in Tank Fuel System
· 60lb injectors flowed by FIC
· Vengeance Racing Custom Stage II Blower Camshaft
· TEA Dual Gold Spring Kit with Ti Retainers
· Comp 7.400 Hardened Pushrods
· Katech C5R Timing Chain
· Meiling Hi Volume Oil Pump
· Comp Trunion Kit
· Snow Performance Methonal Injection System
· 180* thermostat
· Pfadt Lowering Springs
· Pfadt Performance Sway Bars
· Pfadt Rear Tie Rods with Bushings
· Pfadt Rear Trailing Arms with Bushings
· Pfadt Solid Rear Subframe Busings
· Pfadt Polyurethane Diff Bushings
· RPS/Hendrix Engineering Street Twin Carbon Slayer Edition Clutch
· Hendrix Engineering 9” Conversion with Strange 3rd Member with 3.89 Gears
· MGW Short Throw Shifter with Race ****
· LPE LNC 2000 Two Step
· SJM Line Lock
· Vengeance Racing Custom Valve Covers with Coil Relocation Kit
· Autometer Carbon Fuel Pressure and Boost Gauges
670 RWHP 607 RWTQ.....550 RWTQ @ 2600 RPM
This image has been resized. Click this bar to view the full image. The original image is sized 1023x788 and weights 105KB.
Idle/Rev Vide
http://www.youtube.com/watch?v=41SuGHez15Qo
Old 10-07-2011, 05:14 PM
SilverBullet73's Avatar
Those are some sweet numbers!! Table top smooth torque!! Awesome job guys!
Old 10-07-2011, 05:36 PM
madmax4499's Avatar
like the torque, who tuned this beast.
Old 10-09-2011, 01:04 AM
GTOworshiper9's Avatar
The power and torque curves are works of art. Very nice build!
Old 10-09-2011, 02:24 AM
Samer's Avatar
Good job and impressive numbers !!
Old 10-09-2011, 06:39 AM
racerfox's Avatar
so stock long block except for the cam? and chain?
Old 10-10-2011, 09:57 AM
Thanks for all the comments fellas! Yes this power is on stock internals. only mods were, cam with springs, pushrods, oil pump, and timing chain. We plan on putting forged interals and better heads on soon to turn up the boost and really make some power!
Old 10-12-2011, 01:31 PM
BimmerLSX's Avatar
Very very impressive!!!
Old 10-25-2011, 01:28 PM
Ron@Vengeance's Avatar
Thanx guys!!
Old 10-26-2011, 06:08 AM
Stang's Bane's Avatar
Nice build, not a fan of the green, but otherwise, very nice.
Quick Reply: Vengeance Racing Builds Synergy Green 2011 Camaro. Whipple/Cam/Fuel/Rear/Susp/Meth
