383 Dyno results
Old 10-31-2011, 04:14 PM
wooddaniel's Avatar
Default 383 Dyno results
Just got a dyno tune at EFI alchemy. Car put down 412/393. It's an LS1 with an eagle stroker kit, **** intake manifold with a decent size cam, stock LS1 heads and the basic bolt ons. I thought I would make more power, I think the car really needs some good heads. We'll see what it runs when I get the chance to run it as it feels stronger than what it put down. Oh, also this is through a moser 9" and 6 speed if that makes any difference. Are my #'s on par for what they should be?
Old 10-31-2011, 04:20 PM
wooddaniel's Avatar
Also it was on an in ground dynojet dyno.
Old 10-31-2011, 04:22 PM
djfury05's Avatar
Get it to the track then we can see how close or far off the #'s are.. LS1 intake I'm assuming?
Old 10-31-2011, 04:24 PM
wooddaniel's Avatar
No, it's a lingenfelter intake.
Old 10-31-2011, 04:27 PM
wooddaniel's Avatar
I want to eventually put a blower on this thing, or I woulda changed the heads out too already.
Old 10-31-2011, 04:29 PM
djfury05's Avatar
the **** is a lingenfelter intake? link me
Old 10-31-2011, 04:31 PM
djfury05's Avatar
just post all the specs.. cam specs, gears, tires used on dyno, driveshaft, other bolt-ons etc don't make us ask
Old 10-31-2011, 04:35 PM
wooddaniel's Avatar
234/236 .615/6xx 112 LSA cam, 373 gears, its not the stock driveshaft, moser 9 rear that I know nothing about, I bought the car like this. It was on 18" privat wheels with goodyear Eagle F1's. SLP longtubes catted mids, spintech exhaust and thats All I can think of. I know the springs and stuff were done when the new motor was installed.
Intake
http://buyearls.com/data/Products/Te.../199R10267.pdf
Old 10-31-2011, 05:05 PM
djfury05's Avatar
ahh ok I know that intake.. can't be any worse than an LS1 intake which lops off around 250-260cfm I believe.. get some decent heads/intake on it and it'll pick up a good bit
Old 11-01-2011, 12:57 AM
wooddaniel's Avatar
Yeah, Kinda dissapointed but oh well what did I expect with stock heads. My H/C/I/E Trans Am made 424 with a smaller cam and stock 243's. The Camaro feels a lot stronger though.
That intake is pretty much garbage according to everyone I have talked to, I was told by someone who used to run it that his would leak boost from the gaskets (He was procharged), and dynoed slightly worse than the LS1 intake. I have yet to get a positive review from anyone.
Old 11-01-2011, 03:26 AM
hardcore4sure's Avatar
A 383 needs to breath, with at the very least 243 heads and LS6 intake pick up about 50hp,add ported LS6 heads or AFR, TFS, PRC and a FAST intake..... Priceless!!!!!!!!!!!!!
Quick Reply: 383 Dyno results
